Not really because there are far better simulations around than iRacing,
There thousands of people that build stand alone Mods and or Tracks and help convert various Tracks and Vehicles from one Sim to another.
Remember these Mods and Tracks are freely available to the Sim Racing community FREE and they are made with love and passion for accuracy that cannot be matched by mobs like iRacing and SimRaceway where you pay for the content.
https://www.sau.com.au/forums/topic/345986-iracing/page/4/#findComment-7519998
Laser scanning is only part of the story, there are many different factor's that give you the feel of various race tracks , BUT I concur Laser scanning does not make the track any more accurate, I have driven on some IRL and then in the sim both laser and non laser, and to be honest I could not detect any difference.
https://www.sau.com.au/forums/topic/345986-iracing/page/4/#findComment-7522568
Wanting to get into this, is there a SAU league or something? I have the game and put an hour into it last night.. I want to get bathurst / PI is there any packages or have to buy individual? also whats best V8 supercar to buy..? or they all the same? Why is there 2 ford V8s with different costs :s
https://www.sau.com.au/forums/topic/345986-iracing/page/4/#findComment-7525827
Sau league - http://www.sau.com.au/forums/topic/452253-2015-sau-vic-iracing-championship/
Unfortunately there isn't a v8 package. You will have to buy things individually. There are two falcon v8s because one is pre-cotf and the other cotf. Both the falcon and commodore cotf are identical. I haven't seen the prices of the falcons but I imagine the pre-cotf is cheaper seeing as it has been retired.
https://www.sau.com.au/forums/topic/345986-iracing/page/4/#findComment-7525938
Have heard that they recently redid the tyre physics model in iRacing, has anyone noticed the slides more controllable and easier to catch in recent updates?
I am thinking about getting back into it and renewing my subscription once I get a new wheel and setup (my g25 died a few weeks ago).
Out of curiosity what hardware are you guys running (wheel, pedals, shifter, button boxes etc)?
https://www.sau.com.au/forums/topic/345986-iracing/page/4/#findComment-7533087
They redid the tyre physics not too long ago yeah. It's still not amazing, you can slide the cars a little.. But no drifting. Really depends on the car as well.
I've got a fanatec cswv2, cspv1, th8rs shifter, dsd button box :)
  • Like 2
https://www.sau.com.au/forums/topic/345986-iracing/page/4/#findComment-7533426
I raced quite a bit, but got sidetracked by Assetto Corsa which has a few drift cars and tracks. I'm relatively decent in the Star Mazda - usually like 2 seconds off the aliens, however that's good enough to win the occasional race when better drivers aren't around XD
I'm slow as shit in the V8s though. Just can't get my head around those vehicles. Understeering shitbuckets.
  • Like 1
https://www.sau.com.au/forums/topic/345986-iracing/page/4/#findComment-7537613
The Aussie V8's in Assetto and GSC as well as rFactor WILL go exactly where you point them and it is ALL in the Wheel and the actual setup as it applies to the actual car or Mod.
as long as you're on the gas and the rear wheels are slipping
otherwise it's understeer city
there's a huge learning curve with them
https://www.sau.com.au/forums/topic/345986-iracing/page/4/#findComment-7538280
  • 9 months later...
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
