  • Replies 121
dude, do yourself a big favour and start reading.
this place is arguably the best knowledge website for RB performance in the world.
plenty have made around 300rwkw(400hp) on stock motors, that's pretty much the limit and best compromise for power/lag as well given most are street/daily driven.
im not looking for 400whp
we looking for people who has made over it and its reliable
so far i haven t seen one person post up proof of it.........
so whats your problem?
don t tell me your one of those guys with less than 400whp on a built motor? :)
Seriously dude, stop being a dick. R31Nismoid is a ridiculously helpful and genuine guy.
PM me in maybe two weeks or so and I'll hopefully have gotten my act together and sent my car in for tuning. By all accounts I should be making a pretty easy 400+rwhp on a stock 25 with very good response.
Get your act together, or scroll up the page and log the f**k out.
I made 394.8rwhp (294.4rwkw) on 15.9psi of boost on a 100% internally standard unopened series 1 RB25DET, assembled in 1993. This was running a restrictive ceramic cat converter. I can guarantee you since I've bashed that cat out my boost curve holds all the way to red line, and I would be exceeding 400rwhp.
don t tell me your one of those guys with less than 400whp on a built motor? :D
Comments like this wont get you far on this site bud...
What R31Nismoid is trying to tell you is have a look at the RB25 dyno thread there are 30+ pages of peoples results!
Not to mention just running a search in this section.
You are going to get much better results doing this than simply sitting here and waiting for everyone to hand you every bit of info.
^^^ exactly we alone have more than a handful making that power on std engines.... one is on the hoist atm with a broken gearbox.. so if you add up all the shops were talking alot of cars making over that hp....
:D
400rwhp is about "the limit" for more reasons that just outright stregnth.
You have to understand the basic dynamics as I said. People with stock motors fit the following:
1. Generally drive the cars daily.
2. Do not want to rebuild @ a cost of 6-10k and indefinite time off road. Overall setup is budget limited.
3. They want good response and 400rwhp(280-300rwkw) is the "sweet" spot for power vs response and turbos like the 2835 or 3071/3076 fit in nicely
4. Don't want tyre frying monsters
You will not find "proof" of "many" people over 400rwhp/PULP/stock motor - because people don't want to push that fair as per above reasoning.
If you want more than 400rwhp generally people are racing and therefore go chasing 500rwhp or MORE. There is no middle ground there and it seems to jump markedly.
Read the dyno results thread you would see this for yourself.
FYI, I used to have a built 370rwkw RB25 back in '05/'06 :)
As it stands, you have a cheap truck turbo that is worse than a old t04. If you put a decent turbo on there your lazy 400rwhp car would turn into one of the fastest 400rwhp cars around simply because the average power would be ridiculously improved.
If you want more than 400rwhp, then just get a GTX3076, E85, you should see 350rwkw easily enough.
Ensure you have adequate money set aside for the rebuild. As it will die, its just a question of when.
:D
To OP:
Yup, one batch of bad fuel, a missed shift one day.. anything could kill it as its stretched to it limits.
don t tell me your one of those guys with less than 400whp on a built motor? ;)
Um Post #11 in this thread. :(
My cars been at 480rwhp stock internals for over 2 years and loving it. Nismoid has his P.O.V. which is fine (that 400rwhp are the 25's max), i have seen plenty of results to dispute that but each to their own. And yes PULP is not the way to go for reliablilty imo E85 FTW
yup thats y we re on e85 with a shit load of meth injection lol....
what kind of dyno did u do 480 on? and if ur from australia do u have quarter mile mph to back up the power?
thanks for info
To OP:
thats y u nismo guys need to add lean cut to ur fuel managment!
this is a feature we use on the hondata s300
how it works is we set it up to lean cut at 11.7 a/f after 5psi of boost
so lets say one injector dies or u run outta gas it will cut just like boost cut :(
Yep, can be set up with most ECU's that accept a wideband input I'd assume.
FYI, I used to have a built 370rwkw RB25 back in '05/'06 ;)
r serious about the turbos
look at the two video s i provided
the car with a stock rb26 with stock turbos has a bad ass powerband-
on the other hand the car with the hc1 makes 30 more hp-
-now the badass power band will win rite
not...........the laggy hc1 turbo pulls so much harder and killed the rb26 (we raced them)
if u as me anything under a gt40 is too small for a 6 cylinder when a 4 banger with 1.6liter can spind the shit outta it!
mate if you think peak power is the be all and end all and you JUST want to drag race, then good luck to ya.
i prefer a car that's fast in the hills and on the street, which peak power and poor response serves little purpose as area 'under the graph' is king.
lol @ anything smaller than a GT40 being too small.
im just telling him whats real
-instead of hateing he should be particpating.........
who knows what if this motor makes it to 600whp and lives
-i think its posible
look at our honda motors
a b20 is the thinest sleeves and people would crack the sleeves at 7-9lbs of boost......
for years thats what everyone though...
-now after our test we have quit a few of them at over 20-psi with 400+whp(stock block!)
-from this i say since a stock honda block with tiny rods and weak rod bolts can take 100hp per cylinder
why can t a rb25 factory turbo motor take 100whp per cylinder.......
that s what people say when they ve never been in a big turbo car........
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
