im just telling him whats real
-instead of hateing he should be particpating.........
who knows what if this motor makes it to 600whp and lives
-i think its posible
look at our honda motors
a b20 is the thinest sleeves and people would crack the sleeves at 7-9lbs of boost......
for years thats what everyone though...
-now after our test we have quit a few of them at over 20-psi with 400+whp(stock block!)
-from this i say since a stock honda block with tiny rods and weak rod bolts can take 100hp per cylinder
why can t a rb25 factory turbo motor take 100whp per cylinder.......
yea you get the off motor that can make more than the average.
I've seen first hand a stock bottom end 26 make 500rwkw, so what?
it didn't last long.
if you actually ho back and read my post and take it in, you'll see/understand why most don't want to push the limits.
  • Replies 121
that s what people say when they ve never been in a big turbo car........
This thread is getting f**king retarded...
You're obviously here to argue and not take on some of the advice/info being provided to you from some very knowledgable people, so why bother starting the thread? Stick to your fully sick Honda's and your 'monster' 400hp and continue to be envious of our Aussie built RB's :(
So we go from stock engine to just stock block or what? Most of the people in here seem to be talking stock engines, as in, unopenned - not stock block.
Compare apples and apples.
You honestly seem to be more set on trolling rather than learning from the wealth of experience on these forums.
yup thats y we re on e85 with a shit load of meth injection lol....
what kind of dyno did u do 480 on? and if ur from australia do u have quarter mile mph to back up the power?
thanks for info
Mainline dyno's and Dyno Dynamics (not in shoot out mode) all ranging from 348-356rwkw (it has been on 4 different dyno's), never been on a hub dyno. I'm from Adelaide, South Australia which hasn't had a drag strip for 8 or so years so no slips to back up power.
my mate with the 25 s14 was tuned by 101 in brisbane so not to sure what dyno but the car was used for drift. i think he ended up spinning a bearing. mind you he rebuilt it back to standard and untill he parted the car it was going strong for over a year.
dont be so abrasive. you sound like a wanker.
been making 430rwhp out of a stock internaled rb25 for over 2 years now.
car is thrashed regularly, and sees drift days, circuit days, hill runs and has done 1 boring ass drag day.
car ran @ 12.9 @ 119mph with full drift setup as drag racing just not worth altering the car for
figure has been made on multiple dyno's including hub and roller.
car makes full boost by 3400...
Read the dyno thread, proof of lots of 250-300kw rb25s with all the details of how they got it
you are using a laggy shit dinosaur turbo, you will never get good results, peak power sure but a crap powerband. Get a decent garret gt28 gt30 style turbo to match your power levels and you will get better results.
Edited by Rolls
dude in post 1 says he is on e85 ash which is why i thought it was relavent
otherwise its 385rwhp on pulp
as it states
we r on e85 with a big jet on meth injection
-for u guys that r too scared of alchol try it u will never turn back!
wow! its 2010 guys by now we should all know
Gasoline is for washing parts, alcohol is for drinking and nitro is for racing!
man up....
You do realise that methanol isn't nitro...
I love when my stereotypical hatred for Americans arrogance is always confirmed whenever I converse with one ;)
yea but we have used nitro and not afraid of it
-unlike all u we have tested it
-if nitro isn t so expensive we would be injection it with methanol.................
now that will jump hp....
the thing is that was then
now we have better techonolgy and cheaper race gas(e85)with meth injection.....
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
