hi guys, i was just wondering how much power the stock clutch handle. my car is R33 Series II GTST (190kw running at 11psi)
coz i alway feel the gear shift is not soft and a little bit sudden. i can alway feel a forward push when i change the gear.
is it because of the power? or some problem with the gearbox or clutch?
your stock clutch should handle 190rwkw fine.
As to the sudden engagement,from my experience, its more to how fast you shift and how you use the clutch. If you want softer engagement, try to engage the clutch just as the rev drops enough for the rev needed for the next gear (its all about timing,took me a while to get the hang of it), or you can ride the clutch a bit for softer engagement.
But if your racing, doing fast shifting, dont expect any smooth engagement without burning the clutch:)
my stock clutch struggled to handle around 150rwkw. There not the best OEM clutch
are you sure its a stock clutch? sounds like it could be aftermarket as the stock clutch is pretty smooth and you should be able to get it to change smoothly if it was the stock clutch
yes, im pretty sure it's a stock clutch.
that's pretty much stock power for a 33. your clutch failed cause it was fucked and worn out, not because you were making too much power.
my stock clutch gave up at 214rwkw, revs would just flare under hard acceleration, selecting and changing gears wasnt a problem though
exactly. when you are making too much power for a clutch you will floor it and the revs will rise but speed won't (as if you are riding the clutch).
sounds like the OP just isn't that smooth at changing gears, or at least with how quick he releases the clutch.
i think a lot of it comes down to the condition of the flywheel as well. a car that has had a slipping clutch for a while probably also has a rooted flywheel, and if you put a new clutch in it and don't replace the flywheel then there will be a limit to how much power it will handle before it slips.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
