Undoing The Locking Nuts On Suspension Tops.
Hey guys,
Bought some standard shocks for my 33 gtr, only need the tops off them (couldn't give a stuff about springs/shocks) but for the life of me can't get the nuts undone at the top of the shocks (the ones on the massive thread). Don't want to strip the nuts so does anyone know of any tricks. If all else fails i'll cut the springs to release the pressure on them.
Tried wd40 and such, the nuts slightly turn, but then I realised it's the internal bit of the shock turning with them.
Any tips?
Cheers,
Ash
get a nice big breaker bar on it and then give sudden pulls on the bar, don't just gently apply pressure as they will turn the whole thing. if you are jerky in your movement you will have more chance in 'cracking' it and getting it undone.
Coil compressors wouldnt be better than cutting the springs as a last resort? :D lol
Yeah tried that too lol. The stock springs are too long for the compressors I have, so did them a bit down at either end and couldn't get enough force on it to relieve the tops. The springs are pretty crappy though anyway so no big loss if they must be destroyed :)
hehhe, good luck with that.
I ened up having to hacksaw it off (very very carefully so as not to saw the thread on the top of coilovers).
Breaker bar and the best socket available so you dont round the nuts off and wind up where i was...
Umm, sorry to ask the obvious but you're holding the top of the strut still (above the nut) whilst trying to undo the nut yeah? Like this (from the coilovers thread):
One of my front struts had the top bit cracked so I ended up sawing the strut in half to get the spring out, lol. Had I only had a pair of locking pliers...
I then put the remaining top half in a vice and finally got the top nut off, just in case I need the strut top for something else later on.
Yeah that's the bit mate. Can't find anything grippy enough to hold onto the tiny flat bit at the top of the thread. The whole strut (inner bit) just turns when I undo the nut.
Will give the breaker bar a go, however if that fails then will break out the grinder!
So you're trying to take the top nut off without compressing the springs?
Yes, my compressors are about a coil too short for the standard springs. It wouldn't be worth me buying longer ones, since I couldn't care less about spring integrity and have a grinder on hand.
Just compress the middle coils, that should give you enough slack to get the top nut off. I used something similar to the SuperCheap tool and it worked fine on R34 GTT stock springs.
Rattle gun will whip these nuts off.
Some shocks have a D shaped shaft where it passes through the spring perch, which gives you something to stop it rotating. Others have an internal hex which lets you use an allen key (with a ring spanner). Best method tho is a rattle gun. Even if you don't own one, take it to your favourite suspension place and they'll ususally undo the nuts for you for a small fee (probably zero if you ask them nicely, or actuaually ever buy stuff from them). They will also have the spring compression stuff to do it all safely.
Another way to compress the springs is to undo the nut while the struts are still in the car. Then jack it up and remove the whole lot (there are several ways of compressing / jaciking off a stub axle etc to make it easier depending on how hard it is to get the strut out, but that's too much to type coz I'm a lazy bastard)
+1 taking it too your nearest suspension shop, rattle gun take 10 seconds- you shouldn't take the nut off without compressing the springs in case the stored spring energy which is now suddenly released imbeds the strut top into your skull.
Compress the spring as much as you can. Put an open end spanner on the nut then get a shifter and grab the top EXACTLY like V28VX37 has given a pic of above. The wrench can be locked from turning on one of the 3 screws.
this will work. BTW, these should come off very easily, they are only to be tightened to 20Nm or some such, not compressed the entire way down the shaft and locked at the end of the thread.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
