I have spent probably 8-10 hours on the phone with Optus over the last 4 days (including xmas) because the error message said the problem was at my end. I was about to buy a new modem tomorrow when everything opens again, lucky the problem sorted itself out!
  • Nope 5
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602783
lol ring optus because SAU is down surely all your other web pages worked
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602831
if theres a site down and you wanna know if its a problem on your end, use this site http://www.downforeveryoneorjustme.com/ and it will tell you.
also yay that SAU is back
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602837
<br />lol ring optus because SAU is down surely all your other web pages worked<br />
<br /><br /><br />
Perhaps you were not getting the same message I was getting, something along the lines of "The problem is with your server not the board. Please contact your service provider". I clearly am not the tech savvy genius that you are, and for that I am infinitely sorry but I don't see how can you lambaste me for seeing that message and arriving at the conclusion that I might need to call my ISP.
  • Nope 1
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602931
When did I ever say that no other website worked. I know nothing about the interwebs, but if I see a message saying the fault is at my end and to call my ISP then that is probably what I am going to do. But theorise with me, is it totally impossible for websites to use different technologies, so that if something is wrong with my service it effects only certain sites, whilst leaving others fully accessible. ie a board such as SAU may use something different than a regular website where one only visits and views as opposed to views and contributes. Maybe you can use your degree in IT and Computer Science to set me straight. You called me out buddy, tried to get a laugh at my expense, maybe get someone to agree with you, maybe a "good call bro" or something, trying to gain affection and/or approval from your peers, maybe you need to feel as though you fit in. I don't know, maybe next time you feel you need to step in and belittle someone you will think first. :)
  • Nope 6
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602945
Its call the internet and the world wide web.
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5603241
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
