I have spent probably 8-10 hours on the phone with Optus over the last 4 days (including xmas) because the error message said the problem was at my end. I was about to buy a new modem tomorrow when everything opens again, lucky the problem sorted itself out!
  • Nope 5
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602783
lol ring optus because SAU is down surely all your other web pages worked
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602831
if theres a site down and you wanna know if its a problem on your end, use this site http://www.downforeveryoneorjustme.com/ and it will tell you.
also yay that SAU is back
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602837
<br />lol ring optus because SAU is down surely all your other web pages worked<br />
<br /><br /><br />
Perhaps you were not getting the same message I was getting, something along the lines of "The problem is with your server not the board. Please contact your service provider". I clearly am not the tech savvy genius that you are, and for that I am infinitely sorry but I don't see how can you lambaste me for seeing that message and arriving at the conclusion that I might need to call my ISP.
  • Nope 1
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602931
When did I ever say that no other website worked. I know nothing about the interwebs, but if I see a message saying the fault is at my end and to call my ISP then that is probably what I am going to do. But theorise with me, is it totally impossible for websites to use different technologies, so that if something is wrong with my service it effects only certain sites, whilst leaving others fully accessible. ie a board such as SAU may use something different than a regular website where one only visits and views as opposed to views and contributes. Maybe you can use your degree in IT and Computer Science to set me straight. You called me out buddy, tried to get a laugh at my expense, maybe get someone to agree with you, maybe a "good call bro" or something, trying to gain affection and/or approval from your peers, maybe you need to feel as though you fit in. I don't know, maybe next time you feel you need to step in and belittle someone you will think first. :)
  • Nope 6
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5602945
Its call the internet and the world wide web.
https://www.sau.com.au/forums/topic/346495-sau-30/page/15/#findComment-5603241
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
