A creek runs under our carpark at work and with the massive downpour this afternoon it burst a huge 3m hole in the ground and flooded the carpark and surrounding offices and buildings, lots and lots of damage done, few cars were completely ruined and no longer start, the sports stadium was filled completely with water. We are on a bloody hill as well, I couldn't even understand how the water managed to pool there, there was just so much that it couldn't drain down the side streets fast enough.
Anyway my car was under about 40cm of water, seals in the doors stopped it coming in but it must have leaked through a few holes in the floor. Exhaust (big 3" one) was completely filled as well.
Muffler no longer does any muffling as the water must have collapsed the baffles or something but it isn't too bad, sounds nicer imo just loud (its a skyline), I jacked it up on a slope and got most of it out then just drove it for an hour to boil the rest out, no more steam but the muffler is still loud, is it likely its never going to quiten down again?
Also with the floors when I got in everything was dry but over the hour the water soaked through the carpets, peeled them back and they are pretty much soaked through, left some towels on the floor to soak as much up as possible but I think it will be a carpet out job.
Its going to be raining for ages to come so I probably wont be able to get them out until the weekend, what should I do? buy some anti mould powder and leave the carpets to dry in the sun for a few days? Or is it guaranteed to smell no matter what I do?
Also is the council liable for this as it was entirely due to the creek bursting through and not just bad rains, every building in the carpark had their lower floors flooded and quite a few cars were badly damaged. I don't mind pulling it all out and cleaning it up, but I cbf buying new carpets and a muffler if I have to.
http://www.adelaiden...67109078?page=3
some pictures of some unlucky people.
Also oil contamination, I am going to do the engine oil this weekend, but what are the chances that the gearbox and engine oil have water in them now? don't want to flog out my motor driving it the next few days until I get the chance to fix it.
Edited by Rolls
had a mate get his ute stuck in a river for an hour and few days later heaps or plugs had green death in them and corroded out. i would hit any plugs that woulda been under with silicone spray, crc or wd-40 etc just to be safe. 40cm should be well below the dipstick?
unlucky mate
Yeah more worried about the breather/filler pipe on the trans and diff, are they bunged up or are they open?
Just removed the entire interior bar one bolt holding the carpet in and it started pissing down again, luckily there is only a single loom of 24 wires (I think) that was wet, shouldn't have to replace anything else.
still f**king gay though, what retarded council routes a river under a carpark.
Also amazing timing I just sold my spare car LAST NIGHT, f**k I wish he didn't turn up.
Edited by Rolls
Hahaha the council didnt put a river under a car park. The building was built over it. If there is a 3m hole in the concrete floor thats a dodgy building. I would be concerned how they built the reat of it.
Easiest way to dry out your car would be to put a portable dehumidifier inside and leave it running. We have a Delonghi dehumidifier that pulls 20 litres of water out of the air each day, so it would do a pretty good job at drying out your car.
I wouldn't be too concerned about water in your engine/gearbox/diff oil. Though if you can't sleep at night because of it, you will only have to drain a little bit of oil from each to confirm whether there's water in there, as it is heavier than oil it will pool at the bottom.
  • 4 weeks later...
wasn't the buiding it was the carpark.
Edited by Rolls
you can't blame the council for floods like this
Have a look at the video link...I'm sure that could be blamed on the council. It's not the flood that caused it per se, it's the fact the water was flowing under the surface of a carpark
Don't you have insurance?
They would pay for the lot - Or even write the car off and pay you out.
Buy back the repairable write off and fix it = easy profit.
You really shouldn't be buying a car like this if you can't afford insurance?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
