I own a GTS-4 auto and I have purchased a R32 gtr front cut.
Just wanted to Know if what mods need to be done to fit the RB26dett and manual to my car?
Has anyone done this before?
Will I need to change wiring harness?
Does the tail shaft need modifing?
etc etc
Any help on this subject would be very appreciated!!!!!!
Thanks again
MEGA :)
Thanks for your prompt replies
Now I know what I am in for (big job:( )
But the front cut should have Most of the parts that I require for the conversion? including the short clutch master cylinder?
Should I change the whole harness or can I Just use the section for the air flow meters?
cant wait to get it in!!!!!
gee I sound like a virgin :lol:
lol
MEGA
Whole harness for engine.
I had a gts-t with rb26 and it used the whole harness, even injector clips etc are different.
Yes its a reasonable job, but whith a half cut you should have all the bits really except tail shaft. Had you just bought and engine and box, even with computer and loom as you can all ready tell you would then be in the **** looking for lot of bits.
E
High Octane 3 will feature the project you are currently considering.
Basically remove your engine+drivetrain by unbolting your engine+gbox crossmembers and drop engine+drivetrain out under the car, change wiring, add all clutch pedal related and use as much parts from frontcut as possible, reverse the removal procedure to bolt up 26+gbox. GTS4 is so much easier to do 26 swap compare to GTSt..
Good idea to also change fuelpump. :)
That some handy info thx japtaxi !!!!!
Sure will change fuel pump! (might add swirlpot while Iam at it)
Is high octane 3 out now?
Can you remove the crossmembers and lower the engine-gearbox rather than lifting it out the top?(maybe for 2wd not 4wd)
Also do I need to change the wiring near the computer or maybe just modify?
Will I need to change wiring on the gear box aswell?
thanks heaps again:uh-huh:
MEGA
You'll have to check their web for more detail:
http://www.highoctane.co.nz/
Maybe try email Ketzal and ask for more detail? ;)
I think I meant to say unbolt the crossmembers and then engine/gearbox come out under the car in one go... any experienced shops would know that :D Taking engine out from the top will take ages, simply due to messy twin turbo plumbings and so on.
Since you are changing from auto to manual gbox, you only need to hook up speedo and reverse to the main gearbox. You will need to consult other ppl worked on GTR to see about the wirings for transfer case etc... (I only have R33 RWD gbox so don't know much :) )
Probably safe to change all the wirings at ecu side as well? (save the headache from time consuming process to modify) there are ecu pins used by 26 but not used by 20. (2 AFMs signals for examples...)
Make sure you take plenty of pics through out the process and post them on web somewhere.
Haven't paid for mine yet but it will cost $6500 AUS for R32!
I've heard them go for $7000-8500 for engine/gearbox/electrics
Big thanks to japtaxi for the much needed info!!
MEGA
P.s try http://www.japanesemotorsport.com.au/nissa...san_engines.htm
for more info.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
