Hey Guys and Girls,
Well with the Show fast approaching the Show and Shine Event Committee have been putting together an accomodation package.
What I would like to know is who is interested in coming up to stay the night on the Central Coast on Saturday the 27th of March to stay away from that early morning and maybe have a few beverages without having to drive home! :P
I need to know obviously if it will just be you (and if you mind sharing a room?) or if you will be bringing a mate/partner/family along?
Hotel Detalis:
Waldorf Apartment Hotel
18 Coral st
The Entrance
NSW 2261
www.the-entrance-waldorf.com.au
Room Details:
2 Bedroom Apartment
1 x Queen Bed
2 x King Single
1 x Fold out sofa
$180 per night
1 Bedroom Studio
1 x Queen Bed
1 x Fold out sofa
$150 per night (corporate rate available)
Free secure parking available for Hotel Guests only.
I'm going to try and get the corporate rate, which is significantly cheaper, but I need at least 5 names first...
Dan and Committee.
  • Replies 120
Will fatz be coming along and demonstrating his base jumping skills? :P
If I wasn't working I'd be coming up. :)
see Kel, *everyone* except you thinks a drunk person falling off a balcony, bouncing off a car and landing in a bush at 3am is funny.
Sorry guys, I'll be heading up with all our cars on Sun, see you up there at Sparrow's fart.
BTW does anyone have an estimated drive time to Mingara? 1hr? 1.5hrs?
Maj - this is most prefered by myself... theres a motel there called Galaxy where i have stayed before... its shitty enough to be a goer and i think theres a bar/pub there too?
Christian
hmmm... how long is a piece of string?
your stumbling distance maybe somewhat longer/shorter than mine.. i'm tall and can cover a lot of ground in only a short stumble.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
