I gave a freshen up a little while ago but still factory internals. I change the oil every 5k with out fail and sometimes more often depending on what Ive used the car for. Yeah cam caps was the original colour but it was still a lot cleaner than most SR's
Edited by slippylotion
You can't replace the rear wheel, it is attached to the shaft. By the time you replace all the seals and bushes and get it balanced you will be far beyond $500 I assume. Ring Stao (hypergear), he would be the cheapest around for a rebuild quote...
While I'm here may as well report that my little Kando td06 powered 33 finally got out on the track..few hot laps at Phillip island and no busted wheels yet that I know of...
Felt good too, pulled like a steam train right through 5th gear down the main straight, blew the doors of some poor chap in a wrx but you could feel it well and truely runs out of legs by redline..
There was a couple of corners where some extra response would be nice too..
Think the car was overdue for a good flogging, cause its running much nicer now than it has in ages..
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
