My car blows fireballs the size of a car so i dont think its running lean, :yes:
I backed the boost off to around 16psi from 22 to control the heat, it was stupid hot at winton this weekend. It did make a difference, as it should.
Very low timing will result in excessive exhaust heat. It will cause the thing to run really hot, ping earlier than it should when trying to run more boost (capping power) and will also make it get on boost quicker.
I have had a setup tuned like this and am speaking from experience. The car got on boost fine and when/where expected (if not earlier) but the power delivery wasnt right.
No cat, does have a straight through muffler and a res though,
The AFR's were a little rich on the dyno, not heaps just a little to be safe, from memory they were around low 12's high 11's i think. I'm pretty tired from the weekend, i could be wrong i will check later today gonna go see my tuner.
Then yeah could also be timing as above
When you say low timing to you mean advanced or retarded?
The car had around 40-50 on the knock. Nothing drastic.
My car had numbers lower than 10. The tuner couldnt dial in more because the boost was too high straight off the actuator. If we had a lower pressure actuator it would have been a different story.
Is this hitting any points with your setup? whats the lowest boost you can run and did your tuner go all out on the tune with low boost first?
My understanding is the best way to tune works like this: Start with the lowest boost possible and most aggressive tune, slowly wind the boost in and soften the tune as you go.
Rather than get fueling right then add boost and slowly add timing - doesnt work.
I don't think my timing was any lower than 10. Pretty certain it was all higher than 10
We didn't completely reset the boost. Lowered it too around 14psi and went from there. I blew the gearbox on the weekend so once I get it back together, next year, we'll put it back on the dyno to check it again before I buy another 3540 and sell the Kando.
Not giving up yet, i wanna get back on the dyno and have a little more of a play, but i dont think that will change when the turbo spools up and starts running out of legs.
out of curiousity what turbo are you running? what size rear? how much power are you making?
Mook what state are you in? Maybe send your rear housing to Stao (Hypergear) and see if says theres a problem with it.
He stocks these turbos too at the moment. He will be able to directly compare yours to one of his 10cm's and also be able to check for defects. If its not right he can supply you the new housing.
I'm in Victoria, Hypergear is in too melb isnt he?
I'll be able to go see him first, that way i might use a little less time playing on the dyno.
FROSTY, I was a bit disappointed when we tuned it, though its not so much about how much power it made as when and how its making it, very early and seems to run out of legs at high revs, let alone the heat issue.
see to me doesnt seem right! are you sure you got delivered the right turbo??!
do you have a dyno sheet i can look at?
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
