Da Bitch Is Back
No not terrance, my car is back on the road as of Saturday. ;)
Stage 1 tune on sat at racepace we got a best of 256kw@wheels at 1 Bar and then ran the a/f ratios a flat 12 and got 250kw@wheels. We didnt play with the adj cam or anything as yet coz I aint running any BOV's at the moment so I now have the DUT DUT DUT VL noise when I get off the throttle, but its sending the afm crazy with all that air going backwards and hitting the turbo blades and causes the car to stall if I get off the throttle hard and am not in gear. Go a set of R33 GTR BOV's going on hopefully this week so we can play with it a bit more and see what I get.
I couldnt run anymore boost coz I was only running off the 1 bar spring in the external gate and nige did not want to run my profec b with the external gate coz it dont control boost that well apparently with an external gated turbo.
Car is surprisingly easy to drive off boost and still has alot of low down torque below 4000rpm, but just on 4000rpm it will hit 1 bar boost and pull all the way rather quick to 7500rpm redline.
I took a few pics last night in my garage after the skid pad training day where I gave it a good run in, but the engine bay is filthy and theres wires and shit which I havent had time to reroute and clean up as yet.
https://www.sau.com.au/forums/topic/34807-da-bitch-is-back/
  • Replies 78
looks sweet!
Its actually quite filthy in there, its been sitting at the workshop with the bonnet open for around 3 months so it preety dirty. I am getting it steam cleaned after my bov's catch can and all the messy wiring u can see is all tired up this week.
There might even be a bit of blue rich incorporated in there ;)
https://www.sau.com.au/forums/topic/34807-da-bitch-is-back/#findComment-696182
^^^ Seeing that. *cough*shitbox*cough*
How the FARK is my turbo going to fit low mounted ;)
Oh well, it aint my problem ;)
Looks great denham.
250rwkw @ ~15psi. Looking VERY nice indeed.
Mine gets here today/tomorrow.
Cant wait to have a run with ya.
Keep us posted on how it goes with the tuning etc.
And what are you gonna use to control the wastegate etc?
https://www.sau.com.au/forums/topic/34807-da-bitch-is-back/#findComment-696190
All i will say ash is GOOD LUCK getting it to fit low mount without it either rubbing the engine or the engine bay. I had to use brackets to move the power steering bottle forward and a whole bunch of wiring on the passengers side had to be moved otherwise it will melt if it gets near the exhaust housing.
I gotta get an exhaust blanket for the exhaust housing also coz it blows back a bit of heat into the cabbin at the moment.
https://www.sau.com.au/forums/topic/34807-da-bitch-is-back/#findComment-696213
yer i was donw at ice when gerald n nige were explaining to me all the crap they had to go through just to fit that thing in there, but as you'd expect from ice it turned out sweet, hurry up n get that rebuild denham, unlock the full potential ;)
Forgies etc will be very nice and then i can pump 2 bar and make around 350kw@wheels but i have other bill to pay at the moment.
Hoping to have the next tune on wednesday for sat so we can play with a few other things.
After not driving the car for 3 months and now driving it i had a smile on my face all the way home after driving it from niges house to mine.
https://www.sau.com.au/forums/topic/34807-da-bitch-is-back/#findComment-696245
I will be waiting awhile coz its lots of fun at the moment, but i might crack it upto around 18-20psi for 300rwkw for a few calder runs with some nittos and some better fuel. I think my z32 afm is a bit shagged also, so gotta test out another one coz the stalling problem shits me up the wall!!
BTW nathan theres a few secrets that Ben and Nige wont tell you coz they only tell high mount manifold turbo owners. wink wink ;)
https://www.sau.com.au/forums/topic/34807-da-bitch-is-back/#findComment-696263
Yeah I was lucky enough to get to see this in action yesterday and it certainly looked and sounded very very nice.
And it was good to meet you finally too yesterday INASNT!  ;)
Good to meet you to man, and sorry i didnt hang around outside the gate after, but the misses was busting to go to the toilet so i had to hook off.
I was hoping all through the skidpad yesterday that nothing would break coz the turbo only had about 150 km run in before the tune and light thrashing i gave it on the skidpad.
https://www.sau.com.au/forums/topic/34807-da-bitch-is-back/#findComment-696267
LOL
and hey is it you thats using my hand controller!!! i want it back lol
neeeed to see ricey display, its killing me with no hand controller rice, withdrawl *twitch*
https://www.sau.com.au/forums/topic/34807-da-bitch-is-back/#findComment-696273
I know we gonna need it.
But wires etc, i'm lucky. All mine (being R31) are not there etc. And the bay has a slightly different design.
But mine sit's VERY low. So i wont need to move the P/S stuff luckily. Just need to make a add-on to my haet shield that i've already got.
Gonna be good fun. How does it feel?
Nice and responsive?
https://www.sau.com.au/forums/topic/34807-da-bitch-is-back/#findComment-696292
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
