Da Bitch Is Back
I know we gonna need it.
But wires etc, i'm lucky. All mine (being R31) are not there etc. And the bay has a slightly different design.
But mine sit's VERY low. So i wont need to move the P/S stuff luckily. Just need to make a add-on to my haet shield that i've already got.
Gonna be good fun. How does it feel?
Nice and responsive?
I was very surprised how much low down torque it has. U can drive in heavy traffic changing at 3000-3500rpm and it feels like a stockish car, but more than half throttle near 4000rpm and the turbo come on nice and hard.
I havent had a chance to test it out properly yet, need to find a nice cough*private road*cough to open it out.
I had 1 print out of the dyno graph but it got wet and smugged on sat when i was moving some stuff from my car to the garage and i left the graph on the bonnet and it started to rain and it got farked up.
  • Replies 78
I had an etag sitting on the dash on the way back from the skidpad day yesterday, and merging off the the tulla freeway on the westgate freeway i went from 5th to 3rd and gave it a bit of curry upto 6000rpm and the etag flew straight between me and the misses and hit the back windscreen rather hard. I shat myself if it hit me or someone in the backseat in the face it would have left quite a bruise, so theres a few g's when the turbo gets on full song.
Looks hot Denham. I'll be taking my car down to ICE aswell for some upgrades, Gt3540 turbo, ext gate, injectors, rail, pump and power fc but I'll be utilising the standard exh. maninfold, aiming for similar power as to what you got. ;)
lol, it does fit I've had an adapter plate made up. I've trial fitted it and seems to be fine. sits nice and low, though I don't know how responsive it'll be. If it turns out crappy I'll just have to go for a custom high mount setup, and not be tight ass... ;)
lol, it does fit I've had an adapter plate made up. I've trial fitted it and seems to be fine. sits nice and low, though I don't know how responsive it'll be. If it turns out crappy I'll just have to go for a custom high mount setup, and not be tight ass... :D
A 3540 would be very laggy even with a proper manifold i recon, but it could push u over 400rwkw with cams, headwork etc.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
