Faulty Crankshaft Position Sensor
So i have had an issue with this for some time now, but i really can't afford to fix it. New from Nissan cost $700~800 and then the mechanics cost would probably bring it to $1100~. He said (the mechanic) that you can try find a second hand one... but i really don't think that's a great idea...
So pretty much i am looking for a easy solution.
Problems that occur with it;
(On random occasions)
During idle the engine malfunction light will pop on, and so the fun begins.
Idle, revs drop almost to 0 and car will tremble profusely.
Noise change, sounds like its constantly coughing. (or the engine is flooding)
Slow down! The car will struggle to accelerate.
If someone knows of a person or business i may be able to see, preferably around South east i would be extremely grateful!
I have tried looking around, but usually its the same answer.
Otherwise its reasonably safe to leave it unfixed right? Not like it can really do any harm..
https://www.sau.com.au/forums/topic/348078-faulty-crankshaft-position-sensor/
Do you mean the crank angle sensor? CAS?
Just get a second hand one for $50-$100. Make sure you don't over tighten the bolts that hold it on because that can lead to failure.
Or if you remove the timing belt cover and drive the car like that, make sure you use a few washers to space out the CAS.
They seem to fail by putting to much force onto the spindle inside of it and it seperates from the wheel inside.
Easy way to test it is to remove it from the car and spin the spindle. It should spin very freely and not make any noise. If it is a bit ruff or feels like there is sand in it (it is actually metal shavings) and makes a bit of a grinding noise than it is definetely on it's way out. Once it fails completely you will not be able to start the car.
Thanks for the information! I will give that a go, no noise like the one you mentioned as of yet, and yeah crank angle sensor sorry. The mechanic had given me the wrong information.
Much appreciated :wub:
No worries man.
I had mine fail on me while at a friends place with a pissed of ex gf at the time. Car wouldn't start and I couldn't figure out why. Rage doesn't begin to describe that night.
So yeah, I realise how annoying CAS' can be :P
do u know what the fault code is when the engine light comes on.? r34's have issues with coil packs, which could also be your problem, dodgy coilpacks in r34's bring up a ignition signal fault code. im guessing its a r34.
It is an R34. Well the thing is i was told originally by two mechanics that it was the secondary coilpack. The little computer (the engine scanner) changed from the first scan.
The order of scan that detected fault:
Check Crank Position Sensor
Check Cam Position Sensor. (Faulty may effect performance).
I don't remember the fault code for the coilpack. I am thinking it was code 21? But not 100%
  • Like 1
Yep 21 is ignition signal i.e. coil packs.
I had a stuffed CAS with similar issues as to what you describe above. Mine cost around $500 from memory (parts and labour), they rebuilt it with parts from another CAS.
I'd certainly get it fixed, it's no good for the engine driving around with a malfunctioning CAS.
Just to update, this is my third mechanics results. Kinda seems like he is confident about it.
This is the scan:
Code001:
P132 IGN SIGNAL-PRIMARY
It is costing almost $2000 to fix this.
I was told to replace all the coils. After being dicked around twice before i am a little worried about this. So hard to find good mechanics these days... So only one is failing, i can see a upside to changing all 6. But $2000 for them feels a bit steep.
I will be going to another mechanic who is meant to be quite trustworthy. I guess the adventure continues.
I appreciate all the help guys.
This is the scan:
Code001:
$2000 for 6 coilpacks? wtf mechanic are you going to. Any import mechanic knows about Splitfire coilpacks which sell for $300-$400 brand new??
Stop messing around with dud mechanics and get over to http://www.revzone.com.au/contact-us or http://recustoms.com.au
/end
What you describe sounds like a problem I had on my 33 with the CAS. Turned out to be a crack in the mounting bracket that would let the CAS rotate by 2° or 3°. Putting your hand on the CAS and pushing it towards the cam would change the "note" in and out of tune. Bracket was $20.oo I think.
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
