Could be the soot, but it may also be water in the resonator.
Unless he does really short trips continually I would have thought it would get too hot for water to condense in the resonator?
With just the hiflow cat (instead of the one in the dump and one in front pipe) should be finding it gets hotter further back in the exhaust system now.
Don't have a resonator in atm and is just 3" straight throught to original muffler and it is getting quieter so think the soot build up is most likely settling it down.
It is more due to the design of the Legalis (and the original Nismo for that matter).
You can see in the pic below that there is a resonator off to the right of the main pipe, this is the one I am referring to.
For some reason, it is quite normal for this to have some water in it after a bit of use (have even seen some guys state it is the reason they have put them up for sale on Yahoo - bit dramatic if you ask me)
Have seen that weird little growth off the side before and have wondered how much it might help quieten the system.
Guess it would take a bit longer to heat this part up as the hot gas doesn't flow straight through it so would stay cool enough for water vapour to condense a bit longer than the rest.
Maybe they should put a drain plug in it!
apparently i read in another thread that it sends a pulse noise/signal, when it rebounds off the end, back to the exhaust cancelling out most of the sound(correct me if im wrong - iamhe im sure you will anyway) which could be possible. kinds of like in/out of phase or cross phase in audio i guess.
It helps to quieten it quite a bit (although I have not cut it off my Nismo to check - nor will I).
Here are a couple of clips I put up using a digi camera. As you can see/hear, neither are particularly loud.
Both have a very, very similar design although the pipe to the resonator is angled slightly differently and the rear muffler is completely different.
Keep in mind the dump on this thing is massive, around 4 inches wide oval under the passengers feet. It will definitely sound different and slightly louder.
The drone at 2000 revs is a pain, very hard to get rid of. I cruise on 2500 now and don't hear it.
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
