Ok since my car is bat shit boring and I wanna get back into sliding again after never owning a 6cyl in my
life Id like some opinions on a best suited turbo for the internally stock rb25det. Basically all I aim for
is a cost effective song engine combination that will aid in me sliding like a happy camper once again.
I WILL be using a stock manifold with an external wastegate mod done sponsored by a fellow member 10WRB but
Im still retarded in picking a turbo that would be best suited for wat I want. I have seen a few posts about
a GTX3076 and I do know a 3076 can make 400hp which would be enough for wat I need so Im here for more extra
input befor I lash out and by something to big or to small and Ill end up in tears.
End of the day I wanna be able to bake tyres, have the reliability without goin over the top and to keep it
looking semi stock.
Cheers
Isnt the GT-RS a fairly expensive turbo?
Iv seen a few skyline vary in power from 300 - 400 with these
Id like to keep boost around the 16-18 psi mark if this helps anymore
How much are you wanting to spend? If you're baller, then a Garrett GTX3071R or a Borg Warner EFR7064 would be the way to go - if you're middle of the road then a Garrett GT3076R with internal gate, otherwise something like a Kando Dynamics T67 would probably be pretty nifty for a budget option if they carry on behaving as nicely as people are finding them so far.
Dont wanna fork out anymore then 1800-2000 for a turbo. Just rang MTQ and they are saying that the GTX series will be goin for around the 2k mark
so Ill hang out till they have stock and go from there.
Thats why I gave you a range of options, seeing as you didnt specify a price in the first place. Obviously a GT3076R with internal gate is probably the most suitable option for you.
Nah 2k for just the turbo I was talking about haha.
Manifold, gate, dump is all under control already.
Anything with a GT30 core will bolt straight up to wat I can
get my hands on.
I do like that t67 25g kando turbo aswell but I dont like f**kin around with flanges
n shit cause im far to lazy for that.
I will most likely hang out for either the GTX 3071 or the GTX 3076 and go with either or.
Just had a gander at the Kando Dynamics T67 25g...
Wow lol
Definitely WOW! Just remember that has an aftermarket manifold, external wastegate and runs E85 fuel.
I think the HKS GT2835 Pro S is the best overall turbo out there for a stock RB25 today, 280-290rwkw on 98 with full boost by 3500rpm. Things might change once these GTX turbos come out. Only time will tell.
f**kin wow alright haha.
Yeah see I just wanna be able to bolt it on, ram 18pound through the guts, put fuel in it and away I go.
Obviously Iv missed tuning n shit but you get the point. So ill play the waitin game till these GTX turbos
land here and then do a bit of shopping around, might make up for a late xmas present. If the GTX 3071 can flow
10% more then a GT3076 Id like to see the performance of a GTX3076 .82 on the rb25.
get my hands on.
The Kando T67 comes with a T3 flange so you wouldn't have to change anything :)
Except for your exhaust manifold, external wastegate and dump pipe! Or you have to get some custom piping done to run an external wastegate.
I'd absolutely love to experience a GT2835 and a GT3076R back to back, I went with the GT3076R with the view I might end up going to a built motor and IMHO the GT2835 suits a completely unopened RB25 nicely - but not much more.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
