Three people after vents in a 24 hour period. Will let you know if I hear of any more. EBay has some but normal $70-$100 price.
Cheers
Vents sold for a bargain price.
Common people get your offers in before it goes to scrap for cash.
Also found 2 new GTR map sensors
dash gauges with 140,000km's on the clock, good replacement for you over 200k guys, haha
pedals for manual conversion
stock sway bars
interior lights
glove box
etc
You don't by any chance have this coolant passage thingy that sits on top of the 26 plenum? in the yellow rectangle.
pic stolen from "log in"
post-16364-0-24402800-1298161936_thumb.j
Edited by turboedsloth
Yes I have the part in the yellow box
Sold injector setup with engine. Have some spare RB20 injectors around somewhere but just stock stuff.
$1000 for car without brakes cheapest registrable good body you will get.
Speedo cable near new $40
Front bar $75
Rear bar $40
Tail lights $120 for both
Head lights $140 for both
Intercooler $100
Back seat $20 (top and bottom)
Steering rack $80
Power steering pump $30
Air con parts $100 for all you can get
Front and Rear strut braces $110 for both
Boot $50
Bonnet $70
Doors $50 each
3 door trims/cards $90 (drivers sold)
Arms, bolts, nuts, lines, cables, glass, trim, lights and more
Long gone sorry, only GTR stuff I still have is plenum and throttle bodies, new knock sensors, wiring loom's and cam/timing covers.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
