Hi guys.I currently have a turbosmart boost T ,one of the latest type with the ball and spring and was just wondering if a turbotech would be any better? I will be getting a retune soon with bigger injectors and z32 afm to go with my current turbo which is a apexi ax53b70p25.The common trend with these internal wastegate turbos is that they tend to drop a few pounds of boost towards redline. Cheers
https://www.sau.com.au/forums/topic/348562-turbotech-vs-turbosmart/
there is a thread on here some where thats like 70 hundred pages long about the turbotech boost controller being the best so i brought one in short it was shit. i now have a turbosmart T and think it is heaps better.
I had a better boost curve running the Turbosmart than the blitz ebc I upgraded to, although the ebc does ramp on the boost a little quicker.
Either of these cheap manual regulator style controllers should do the job perfectly. If your boost curve still drops off it wont be the controller, more likely you would need a stronger wastegate actuator.
+1 to turbotech!
Had a GFB bleed installed set to 12psi,
then switched to a turbotech (just to test) and the car hit 12psi so much quicker then the GFB, ditched the GFB immediately.
turbotech will be my only manual bleed valve choice, other then that, EBC it is :)
Thanks for the replies guys. I think i will look into getting a stronger actuator to suit my turbo.Does anybody know if a hks or garrett actuator will fit my apexi turbo?The actuator on it is apparently a 12psi.Cheers.
Buy an EBC. The cheapness of skyline owners never ceases to amaze me. It is scrooge season though I suppose.
So do you believe an EBC will stop my boost dropping at high Rpm,cause if so that is all i'm looking for?
A decent electronic boost controller is always going to be better then a bleed valve if set up right.
Just Jap have the Blitz Dual SBC Spec R boost conrollers going for $599. Its not cheap but you will get great results....
here is my boost graph its holding 22psi with a 15psi actuator.
The actuator is doing most of the work in your setup, try that with a 7psi spring. I have the same Blitz unit, it wont hold boost any better than the Turbosmart as my actuator is blowing open.
The Turbosmart and Turbotech ones are not bleed valves, they are regulators that are run in line, just like an ebc. They are great if hooked up correctly, not just for tight arses.
and a turbotech is not a bleed valve. it's a ball and spring type that blocks the pressure to the actuator until desired boost is reached, at which point the pressure is passed through.
very simple. very effective. very cheap.
but it only holds one boost level throughout the rpm range, and isnt configurable in any other parameters, obviously.
so depending what you need. ebc may be better, or may be a waste of money.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
