Hi guys.I currently have a turbosmart boost T ,one of the latest type with the ball and spring and was just wondering if a turbotech would be any better? I will be getting a retune soon with bigger injectors and z32 afm to go with my current turbo which is a apexi ax53b70p25.The common trend with these internal wastegate turbos is that they tend to drop a few pounds of boost towards redline. Cheers
https://www.sau.com.au/forums/topic/348562-turbotech-vs-turbosmart/
there is a thread on here some where thats like 70 hundred pages long about the turbotech boost controller being the best so i brought one in short it was shit. i now have a turbosmart T and think it is heaps better.
I had a better boost curve running the Turbosmart than the blitz ebc I upgraded to, although the ebc does ramp on the boost a little quicker.
Either of these cheap manual regulator style controllers should do the job perfectly. If your boost curve still drops off it wont be the controller, more likely you would need a stronger wastegate actuator.
+1 to turbotech!
Had a GFB bleed installed set to 12psi,
then switched to a turbotech (just to test) and the car hit 12psi so much quicker then the GFB, ditched the GFB immediately.
turbotech will be my only manual bleed valve choice, other then that, EBC it is :)
Thanks for the replies guys. I think i will look into getting a stronger actuator to suit my turbo.Does anybody know if a hks or garrett actuator will fit my apexi turbo?The actuator on it is apparently a 12psi.Cheers.
Buy an EBC. The cheapness of skyline owners never ceases to amaze me. It is scrooge season though I suppose.
So do you believe an EBC will stop my boost dropping at high Rpm,cause if so that is all i'm looking for?
A decent electronic boost controller is always going to be better then a bleed valve if set up right.
Just Jap have the Blitz Dual SBC Spec R boost conrollers going for $599. Its not cheap but you will get great results....
here is my boost graph its holding 22psi with a 15psi actuator.
The actuator is doing most of the work in your setup, try that with a 7psi spring. I have the same Blitz unit, it wont hold boost any better than the Turbosmart as my actuator is blowing open.
The Turbosmart and Turbotech ones are not bleed valves, they are regulators that are run in line, just like an ebc. They are great if hooked up correctly, not just for tight arses.
and a turbotech is not a bleed valve. it's a ball and spring type that blocks the pressure to the actuator until desired boost is reached, at which point the pressure is passed through.
very simple. very effective. very cheap.
but it only holds one boost level throughout the rpm range, and isnt configurable in any other parameters, obviously.
so depending what you need. ebc may be better, or may be a waste of money.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
