depends on how much??
fixed the knock in the rear suspension, turns out the locking ring hadnt been done up and the strut was slowly unscrewing itself. problem solved! also reset the rear height, gave the springs some preload, so much better now. gotta do the fronts next.
i think the front knock is actually a groan and its the new poly bushes are not greased up enough :(
Good that you found the problem!:thumbsup:
How did you preload the rear springs Iain?
My understanding is that you can only preload if the damper is topped out (at full extension). In our case all you'd be doing is increasing your ride height.
Preloading springs is more of a motorbike thing due to the fact that at rest, with no rider (on a sports bike at least) the suspension is basically at the top of it's stroke (topped out), whereas in a car the suspension sits down an inch or more (at least) when at rest.
well, there is a height adjustment on the strut, so i measured the length of the thread to the ring 'flange'. this pulled the entire wheel assembly up as its shortened the length of the strut. then i screwed the 'height' adjustment of the spring land till it was captive (originally they werent) and then a little more. i measured both sides and they are even now.
the front i didnt touch as i couldnt move one of the rings for the spring land. ill attack it later and preload a little more.
dont wanna be a pain, but do you reckon you could take pictures?
Did the brake wire mod and installed a switch in the top of my glovebox. I did this not because I stall it up and launch it all the time, but because I live in the hills and drive on windy roads every day. Was quite skeptical about how much difference it would make as my car only has an exhaust, but went for a drive last night and was extremely suprised at the difference out of corners :rofl2: . Thanks to all that put the effort in to working the mod out :thumbsup: .
Edited by MOUTH
glad your happy with it. who needs the nismo ecu now :nyaanyaa:
because the stock ECU doesnt advance the cams like the nismo :P
Do the Mines/Impul/Gzone remaps play with the cams? I'd assume they do, but from memory the associated websites for them are all extremely vauge on what they actually 'do' :closedeyes:
lol low end cams? i dont know if Im wrong but I think scotts vmanage showed that the cams are retard down low.
of what part?
and no, not till next weekend lol
whenever your free to do it man, a write up how to stiffen pre load would be good.
Ok, I get you; I already run my shocks as short as they can go to minimise the amount of "droop" available as the shock extends.
Thing is, on mine, at the height I run, the spring is barely captive. Increasing the "preload" wouldn't make a difference on mine. Perhaps my springs are slightly shorter than yours?
thats entirely possibly about the spring length. but i think they are all the same.
the back is now firm, it was a little sloppy before. looking at it when i got home, i think it can go down maybe 1cm further at the rear. the boot was full of my tools so i couldnt throw it around too much.
the front will need to come down, or maybe just preload the springs more
Don't you want some droop? It forces the wheels to maintain contact with the road when you go over a bump. Having too much droop is bad as this will force the car to raise when cornering too much (dependant on spring rates/shock rates etc.)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
