Just got badged, could some one tell me where i can get a rear GTR badge for a r33 & how much?
You're in Sydney, go to UAS.
My mates had his V-spec badged twice!!! Both times they have got them to Tassie in about a week!!!
BTW I'd check all the guys running GTR badge's on their T's ha! ha! just joking, but it is a pet hate of mine, why would you bother???????
:headshot:
https://www.sau.com.au/forums/topic/34947-badged/#findComment-699616
dont bid on the ones on ebay pleaseee :Oops: ...  The top one is mine and the second is meshmesh's :D
I hope you guys realise that you're bidding on fake GTR badges... They're not Genuine Nissan ones, although the one you're bidding on it pretty close, meshmesh's is completely wrong looking.
https://www.sau.com.au/forums/topic/34947-badged/#findComment-699629
Are the badges for the 32, 33 & 34 all the same
The R34 GTR badges are the only one's that are different (subtle changes, but still noticeable at a standstill) Anyone correct me if i'm wrong, HPI GTR special no1 states this.....? The fake one's that are mashed onto GTST's don't look completely right... they look smaller and very toyish :thumbdwn: (unless its a genuine one of course).
https://www.sau.com.au/forums/topic/34947-badged/#findComment-699634
Yeah I realise its fake but dont have $90.00 to spare at the moment for a "genuine" one (which is what JustJap quoted me). And sorry the bottom one isnt meshmesh's :Oops:
Yeah, it's extortion isn't it? :D
Just checking that you realised that they weren't genuine ones... It's all good! :P
https://www.sau.com.au/forums/topic/34947-badged/#findComment-699640
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
