28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Choice of the top 5 from the previous thread:
CS:S 10
BC2 6
TF2 6
L4D 5
SC2 5
Please vote - you can only do it once - So pick the one you'd prefer most.
I'll organise it for this THURS NIGHT if we can get enough votes, otherwise Thurs after ;)
https://www.sau.com.au/forums/topic/349611-sau-gaming-night/
I had to check wikipedia for a couple of these so in the extremely improbable event that I am not the only one capable of such ignorance:
CS:S = counterstrike source
BC2 = Battlefield : Bad Company
TF2 = Team Fortress 2
L4D = Left for Dead
SC2 = Starcraft 2
Edited by *LOACH*
Oh lol - they are abbreviated from the other thread
but then come on, what kinda gamer you think you are if you don't know those? :D
An out of touch one? I remember the good old days of Quake 2 and we used to hang an onion off of our ps2 mouse which was the style at the time.... ahhh back to the nursing home for me
CS never gets old because the mass popularity gave rise to huge aftermarket support from developers. I've spent 2 years of my CS life on scoutzknivez maps alone. Another year on jailbreak maps, another year on gungame maps, another year on mini games maps...it's ridiculous.
lol.
CS:S always turns into a rape session from your brother Ash!
Yeah, I'm the only one who seems to be able to hold his own against him :P
Wow.
Your life sounds super exciting, it should be made into a mini-series with each episode alternating between a different set of cs maps and masturbating.
I played comp BC2 when it first came out on Cybergamer (my team was in the top 8 in aus).
Sadly my pc died, bought a new one and the cd key wont work.. by this time comp BC2 was pretty much dead so never bothered with it.
Ive still got CS:S installed so depending on the night i would be keen for that :)
EDIT - Just saw that this is setup for thursday night and that for me is a weekly sau meet on the central coast so im out :P
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
Ă—
Ă—
