I need to get my rocker covers either painted or powder coated.
One thing that concerned me is when looking under the rocker covers they have what looks like a type of red/pink silicon. The silicon helps seal the sections where the oil breathers & oil filler go.
I went to a powder coaters, he said due to the oil stains in the alloy he would have to get them acid dipped first. (I didn't think Alloy likes to be acid dipped?!?) Powder coat them then heat them up to near 200degree's.
Any recommendations peoples?
I'm after a gloss black look. With some polished bits the gloss black should look nice.
https://www.sau.com.au/forums/topic/34979-rocker-covers-paint-or-powder-coat/
I am sure that painting is fine. Two to three coats of grey primer then four to six layers of the colour then clear for another three times. This will allow for a nice finish and wll stop the heat cracking that happens when not painted properly. You will need to clean the area up so speak to painters etc get what has to be done it should be ok to acid dip alloy not sure but it realy cleans everything off. Good luck budy
I got the rocker covers powder coated bright red on a 4age i had years ago. worked fine.
I got my alloy rims powder coated about 2 years ago and they were acid dipped and glass beaded as well.
The powder coater should know what can and can't be done though...
Painting is probably easier/quicker/cheaper.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
