So I'm told my system is too old to re-gas with what it takes (R12) and rebuilding it all for new gas is ultra expensive (not quoted). I was told possibly someone with some of the old gas cleaner which is now unavailable would prep the system for the new gas type, but you can't buy it any more... Alternatives to this, any one?
https://www.sau.com.au/forums/topic/349879-ac/page/2/#findComment-5633809
