Hey Guyz, Well finally the time has arrived where i can start buying all the parts needed to do up my car, My Goal for my car is 300-320 RWKW with good response, So these are the parts im planning on using, just want to know if im missing anyhting..
My Current Mods are:-
Performance
HKS FMIC
POD Filter
3" Turbo Back exhaust
Spliftfire Coilpacks
Alloy Intake pipe
Handling
Slotted Discs
A1RM Brake pads
Rear Swaybar
Hicas Lock Bar
Tein Super Street Coilovers
Parts to be bought:-
Walbro 255LPH Fuel pump
1000cc Injectors
Link G4 Ecu
Heavy Duty Clutch
Exhaust Cam Gear
Aftermarket Alloy Radiator
Now im planning on getting all these mods into the car and after i save some more coin will be picking up a GT3076 0.82 Ext Wg to make that 300KW,and can i weld on the external wastegate to the stock manifold? Now what i want to know is if im missing anyhting in between or will i be good for the power and mods im looking at.. Will be using stock internals.. Im planning on Running Nos in the future only for drag racing as i have some plans in mind, how would Nos do with stock internals, sorry im a bit of a noob with nos..
Just trying to get my list right before i start buying everything...
Thanks alot guys..
https://www.sau.com.au/forums/topic/350133-need-advice-on-build/
aren't 1000cc injectors a bit much for 300kw? if you want decent response you might want cams, my 3076 is a bit laggy for my liking. especially if sticking to stock mani
my mistake... no cams and internal gate. this will have to change.
Yea well i did a bit of research and spoke to trent also from Status Tuning and he told me to get the ID 1000cc injectors, they are 600$ and idle like normal 600cc injectors, so there aint any disadvantages with these, and later in the future i dont want to change injectors so i can have more headroom. If anyone else is looking for injectors for the R34 Neo these are a good deal, It has a good spray pattern as well as atomization- http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=200509222499&ssPageName=STRK:MEWAX:IT
So is there anything else im missing or am i good?
If you are only going to run one fuel pump you will need something better than a Walbro (and directly wire it for full battery voltage whatever pump you get). Forget the pod just use the standard airbox with a highflow filter unless you're keen to build a shield around the pod. Change your brake fluid to something like Motul RBF600. You can weld a mount for an external w/g to the ex housing of the turbo. I have no experience of NOS but it sounds like overkill on an unopened engine at 300kw.
yeah thats injector you want... i run those injectors in my R34.
but you will need to try and source the connecting plugs.
Definitely listen to Trent. Those injectors will give you plenty of room for the future eg E85 etc.
Stick with the 3" pod and alloy intake pipe.
Not many people making over 300rwkw with the GT3076 0.82 on ~18psi, so will need to run more boost to make 320 or just run E85.
This forum tends to rate bosch fuel pumps over walbro fuel pumps so thats up to you, I have a nismo intank fuel pump which Trent really likes. Its a bit pricey though but will handle more power, over 400rwkw on 98.
If your interested in drag racing then dont listen to the laggy comment, you should not go any smaller than this for mostly straight line stuff. Have you had a look at the GTX3076? Its the new model, looks to make more top end power with a negligible loss in response.
Hey Buddy could you tell me what do i need to get with these injectors, do i need the height adapter and which connecting plugs do i need? Can i just get the plugs from the guy that is selling the injectors?
Well i read the full thread of the GTX turbo's and it does look a bit more impressive than the GT series, might just consider the GTX3076r, what size wastegate u reckon ill need to run 18-20 psi for 300 KW, and i dont have an option of E85 as im taking my car back to india and only 97 octane and race fuel is available, so might tune it with race fuel for the drags.. I'll stick with the walbro for now and when im going to go forged internals and bigger power ill change my fuel pump then, becuase i want an intank pump which is a direct fit and dont have the coin for a nismo one...
I actually got these injectors...
bosch ev14'ds
No height adapter needed they bolt straight in..
For the plugs i took the injectors to these guys and they sourced them for me $11each from memory
auto service solutions
they will need to be solered in to you harness...
bosch ev14'ds
How would u rate these injectors compared to the nismo and blitz one's??
they are a awesome injector.
my car idles perfect.
the tuner spent a bit of time getting the lag times right but thats not my problem :bunny:
Well thanx for that buddy, you just saved me 100 bucks from buying the 1000cc one's... :)
For $100 extra I would purchase the injectors that the tuner recommends. Tuner's are the ones that know how good and easy to tune particular injectors are.
Well its the same injectors as trent suggested, the only difference is that its 900cc and the other one is 1000cc, Im anyways not going to be needing even close to 900cc and considering they are the same injectors, i might as well save 100 bucks.. Harey what size wastegate you think id need for the GTX3076 to make 300-320 kw's at around 20 psi..
90lb is 950cc and thats at 43.5psi rail pressure. so at 50psi rail pressure they flow 1018cc.
thats plenty of injector :yes:
to convert lb/hour to cc/minute - multiply by 10.5
  • 4 weeks later...
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
