95 25t
1. Twin dump pipe full maundrel bent system 3 inch turbo to tip
2. Turbosmart bleed @ 11 psi
3. K&N panel filter (hehe - 1kw)
Rest of the car stock.
How many kws would I have gained do u think?
Next on my list is hybrid fmic, then PowerFC. Hoping for close to 200rwkw
with all that plus good tuning... :bs!: ?
https://www.sau.com.au/forums/topic/35025-how-much-power-do-i-have-not-much/
A power run should set you back arpund $40.
Woah! Is that all... Thought it would be at least $100. Anybody know a good dyno on Brisvegas northside?
Be pretty happy with 165rwkw, that would mean 30kw for $1300. Mmmm $1700 for hybrid fmic but i have nfi how much power gain from that maybe 10 rwkw? I've heard of peeps getting 20 rwkw's out of powerfc though, maybe another $1500 + tune. Should be near my goal then for about $3150.
Should I be looking @ stonger clutch before all this or will standard b ok up to 200 rwkws? Woops forgot a whiteline kit too didnt i...
Hey stop newby bashing u :flamer:
not heaps because with those sorts of mods the std ecu runs rich as we all know and have experienced. I reckon around 140 - 150 rwkw depending on dyno.
Your future mods sound good but I think when you get the power fc, thats when you can make the most of the mods u have.
well as a base idea for u. I got a 12/93 r33 gtst. When i dynoed it, it had a cat back 3 inch, pod filter with no air feed, and boost controller set on 13psi and i made 213rwhp(bout 160rwkw) u would be around that mark i would think. Give or take 10 kw
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
