Hey all,
Please refer to pictures as i'm not 100% sure if i know what i'm talking about.
I believe it's the CAS that's in the fotos?
Anyhow... i;ve noticed that when engine is running the cas is shaking/wobbly.
Is anyone able to tell me if that's normal or if it looks ok how it is in the foto?
There seems to be only 1 bolt holding it on top as well?!
Got the car like that so now sure if it's okay or not.
How do i go abouts fixing it if it's not okay?
What will i need/parts? etcc... and help on how i do it would be great.
Unless it's fine as it is.
Thanks!
https://www.sau.com.au/forums/topic/350791-crank-angle-sensor-cas-help/
it should not be wobbly. I can't see the bolts. I acn see one in the bottom of your second pic, can see part of the slot where the second one goes (top left of pic) but can't see any bolt (but it could be out of frame) and I think I can see the third bolt (top right). and yes that is the CAS - Cam Angle Sensor (aka crank angle sensor). it's find where it is but you need all 3 bolts in place as otherwise it might be sliding around which will be affecting your timing.
1st pic there is a bolt on the right.. but none of left..
so your saying it should be tight and not moving so i need to find another bolt to secure it?!
im told that it needs to be gapped or spaced properly?
or just get a bolt and tighten it all the way in?
thanks.
There should be a washer or something behind the CAS to ensure the spacing is correct, yes. Normally your timing belt cover would be performing that function - but for whatever reason you don't have one.
You should definitely have all the bolts in-place, or yes, there's going to be issues - ditto the spacing.
Have you considered putting the cover back on, and bolting it back up that way?
would make me life easier if i did have it! loll..
car came as is without the cover!
You appear to missing the spacers. These are included in the rubber seal which slots into place in the cam cover. If you tighten the bolts without the spacers the CAS will rub against the cam gear resulting in metal filings. I am guessing the previous owner had discovered this and hence left the CAS loose. Not good. I think the spacers are about 5mm thick. Someone maybe able to confirm.
Also,
1. dont run the engine until the CAS is properly attached
2. check the timing after you've sorted the attachment (there's probably a write up on how to do it in the DIY section)
Also,
in relation to point 1.
the previous owner had always run the car with it like that.
and i've run the car like that for the many months i've had it for!
>_<
a vid will be uploaded in the next few mins for u all to see it moving.
100% right.
Tightening the bolts with no timing belt cover off will kill the CAS, it's just a matter of time.
If the CAS is too close to the exhaust cam's key, it will destroy the CAS' optical sensor and believe me I've destroyed a CAS (not used the spacers from the stock timing belt cover when I put a clear cover on)
It's actually brass washers embedded in a gasket that provides the spacing rather than the cam gear cover per se.
I've heard you can toast your CAS by not having the correct spacing so it pays to be careful.
I have an aftermarket clear cover which has no provision for the OEM washers and gasket, but it provides the (some) spacing instead the way it's designed. I added some thin steel washers myself because the spacing provided by the aftermarket cover was very slightly less than the OEM washers/gasket.
I've heard some aftermarket covers provide no spacing though.
Edited by Tony de Wonderful
Yes what Tony has said is correct.
And yes you should remove the cover from your CAS and inspect it after you fit a cover and gasket/spacer. What you are looking for is the position of the trigger disc, and if it is rubbing on the optic sensor. If it is, you can carefully and gently tap the shaft back to its position in the CAS bearings where it should be positioned... so the trigger disc is central in its position in the middle of the optic.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
