Ok guys,
I think it might be my tie rods that are on their way out.
Had new rubber put on all round a couple of weeks back, with them all being balanced and alligned at a reputable shop.
Between about 80 and 100 km/h I'll get some shake through the steering wheel (fairly minor).
Given the tyres are balanced and aligned, would tie rods be the obvious cause?
James
https://www.sau.com.au/forums/topic/350827-shakey-steering-wheel-80-100kmh-kmh/
No noticeable damage to front or rear rims.
Also can't recall any situation where I could have/would have buckled one.
If it helps problem has increased slightly since getting her in October 2010 which would tend to suggest something is wearing out...
Nice to see someone's breaking new ground with a turbo x-trail as well. Would love to see videos of that haha!
James
Edited by plan-b
I've just had a look at the vehicle report the day after I purchased the car...
There are a few things noted that may corellate to the shakey steering...
1) Both inner tie-rod ends have minor freeplay
2) Both rear outer HICAS ball joints have minor freeplay
3) Both front upper control arms have minor freeplay
4) Both front radius rod bushes weather cracking
5) Front and rear stabilizer link pin bushes weather cracking.
At the time of the report I didn't have these attended to as I felt as if they could be a bit exaggerated to encourage me to spend more money. Now I'm thinking one or more of these things have deteriorated a bit more...
James
These are all parts i've replaced on my R32 over the years due to normal wear and tear. Being a 20ish year old car there's every chance they're worn out!
Yeah straight out.
Might be time for some replacement parts haha.
It maybe the front tie rods. Water gets in behind the boots and allows them to rust and they wear over time anyway.
The tire shop would (should) have picked up on it during the alignment if that was the issue though....
Make sure all the wheel nuts are done up, get the front up off the ground and grab the corner of the rims and move them left to right, giggling them.
It the rim moves without the steering wheel moving there is your problem. Even 1-2mm will cause shudder >75km.
You can replace these, they are ~$80 for the pair.
Alternatively the same for the wheel bearings. If its a bearing the tie rod wont move in and out, but the rim will have 1-3mm movement in it.
Cheers bro, good info.
I've noticed that if I'm driving in a quiet area without the and I pass islands with thick shrubs or if I'm driving down the freeway next to concrete walls I will hear a faint clicking/ticking sound that appears to be coming from one of the front wheels. It's not a sticky caliper piston or anything of that nature and its a far more subtle sound which is only heard if its amplified by a barrier/shrub/line of trees etc.
I'm wondering if this is the first sign that a wheel bearing is on its way out?
James
I had a front wheel bearing go in my 32 and it would click at low speeds, also would tramline bad under brakes.
Definately look into the wheel bearings.
Yeah mine tramlines a little as well on braking, seems to be originating from the front right wheel.. I'll also get the feeling that im driving on an angle when im straight (and no its not YAW its some weird tramline sensation).
Will be getting all wheel bearings checked out very soon.
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
