Winge, winge, f**king winge. I have piece of shit D2 rock hard suspension and i still love driving out that way! Sure the road has some bumps, but really it aint that bad. Slow down for the big ones and dodge the rest!
Amen brother, amen. :D
I went out there Tuesday night. Unfortunately Rush Hour were out there doing their normal shit and just had a few runs of the top section.
I'm not sure if it was this thread, but the gravel on the road is only about 10 meters, on the area where the rock face had been cut away near the camping area.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
