Hey mate, you wouldn't happen to drive a white R34 with jdmst sticker on the left hand side rear quarter window, would you? :O
hahaha yeah thats me, how the shit did you work that out ? :S
  • Replies 124
ahaha, wouldn't happen to go to mitcham kebabs from time to time?
this was awhile ago, but was there once when (who i'm assuming was you now) was just leaving, and car sounded fckn hawt (:
saw it had a twintip, and when i read this thread thought...maybe..LOL. what are the chances xD.
Heres my N/A with a HKS exhaust.
Wow, catless NA making flames? Cool. Sounds good. How does the car feel with and without a cat? I'm assuming after a 3", catless would provide even less 'backpressure'. Ta.
Also are the kebabs in Mitcham as good as the Footscray Kebab House ones?
Edited by TyresBro
Yeah I've never had the one's from footSCARY either :S
I've heard good things about coburg, though? Gotta try them sometime.
But really...mitcham ftw.
Haha lol definitely should do that. Should start there as well.... :P
Didnt really make much power being 4wd around 110-115rwkw
heres a vid of it in the motorkhana http://www.youtube.c...u/3/IICEnPMFPzg
Not very descriptive :P Not bad for NA though. Tyre squeal sounds loud. Did it feel like the mid range torque dropped with the cat out? Or improvement?
Would also be interested in NA cruise lol. Buzzboxes roaming the streets. Also if you do plan on going to the Footscray one, don't go at night as that place isn't really ideal to go late if you know what I mean lol. It'll be across the Commonwealth Bank incase I'm not there.
  • 1 month later...
Hey guys, nice post!
My cars got a custom 2.5" mandrel bent mild steel cat back, the usual recommendations, i got it second hand off someone in the forums, center muffler included!
The muffler at the end is due to be replaced soon, I was told it'd crack in about 6 months time (when i bought it which was well over 6 months ago I think - but I don't really drive all too much anymore these days so perhaps thats why)
I'm not a huge fan of cannons in general, I prefer a more subtle look and was planning to replace it with a good oval twin tip muffler on the end ..
Any brands recommended?
in a sort of answer to my own question, ive seen a few people recommend varex, magnaflow and lukey (which are apparently quite similar but lukey slightly quieter .. in which case id go lukey!)
any other opinions?
sounds good mate! :) I have pretty much the same system but I've got a cannon on the end (it came with the 2nd hand exhaust I bought)
Was considering getting the varex muffler, sounds good, I was considering Lukey/Magnaflow before though
thanks mate !!
i'd go magnaflow over lukey, lukey seems to be targetted more at commodores/falcons than imports.
on my old VS calais, it came with a full lukey exhaust (extractors too) had a nice note but was very quiet :S
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
