I kinda just jumped into this because I accidentally starved my HX35 7blade of oil :( . A word to the wise, don't us F'ing stock Nissan oil feed fittings! There are _THREE_ hidden ninja restrictors! So I landed a brand new billet 5557 T3 .82 a/r rear for a good price. It will be going in my s13 with 25DE/30 with a tubular manifold (unfortunately its a T4 divided manifold so i will have to make an adapter :( ). Damn shame I don't get to put the twin scroll to use!
Looking for a very responsive street setup and a relatively quick 1/4 mile dragger (hoping for 11s!).
I know the new generation of Precision turbos is relatively new, but what do you guys think; Will i accomplish my goals above? Should I have gone larger so I could utilize a T4 divided setup? Is the T3 .82 going to run out of puff?
Thanks guys!
https://www.sau.com.au/forums/topic/351669-precision-5557-in-an-rb30/
But how can such a big turbo have the response that I'm looking for? The guy says "The GT4088 could be up your street, good responce and I dont think it ran out of puff." Good response? A GT40!?!?
Edited by ST240
Thanks guys!
I have a 5557 on an rb25... It chokes the 25 and only makes 245rwkw at 20 psi... Sell it.
Did you read that link I posted?
"a 1.06a/r T4 twinscroll housing builds boost faster than a .82a/r open T3"
"From that result I'd be picking a 1.05a/r twin scroll T4 EFR8374 to be an absolute torque monster on an RB30!"
Read through the RB30 dyno results and pick a turbo from there.
Would be such a shame to not use the T4 twinscroll manifold!
If your after maximum response and dont care about wasting your twinscroll T4 manifold then go a 3076 0.82. Can make a super responsive 300rwkw, check out Al's setup first dyno on Page 4 of RB30 dyno results.
You can get a GT3076R in a 1.06a/r twinscroll - that'd be insane. EFR7670 would be crushing, GT3582R power with better than GT3076R spool
Forgot about the 3076 in 1.06 twinscroll T4! Dont know much about this EFR7670, will have a read.
Serious? The thing is rated at 525 crank hp. What rear do you have on it?
Wow I can't believe a T4 1.08 twin scroll spools faster than a T3 .82!!!
Isn't a 5557 somewhere between a GT3071 and a GT3076? I have the .82 rear. I saw Al's setup and thats what I'm pretty much hoping for.
Damn. Looks like I might be selling it :( .
Edited by ST240
Jeez Justin I just read your posts in the Precision Billet Turbo thread. Disappointing indeed.
I would be quite pissed if I ran the 5557 up to 20 psi on my 30 and didn't make 300 kW. I wonder how inefficient that compressor is at its "525 HP rated" capacity...
Maybe I should just be a guinea pig and run it ;) .
I have a .82 rear... drops off 21psi to 18psi from 6k-7.8k rpm and wont make any more than 250rwkw on 98... The response isn't particulary awsome for the power either..
Sell it!
Sell it!
Hmm...no wonder they never really put any test results of this combo up on here.
Sell it!
I coulda sworn I saw you say you had a .63 in that thread...
Well sports fans.
I'll post up the dyno sheet tomorow.... However-
I ended up making 245 odd rwkw on 98 at 20psi (that drops off to 18psi at 8000rpm) from my 5557 .63 exh housing. All the usual supporting mods, no major restrictions.
I was a little dissapointed. For the lag I would have expected 255/260ish rwkw at that boost level.
It seems high boost is needed for the numbers with these turbo's. I just didn't want to run anymore boost on a stock 100k rb25.
I'll be going to a td06...
J.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
