Parting out my 1995 Skyline GTST which has been in a accident. Everything from front to back EXCEPT FOR the front calipers, engine, computer and gearbox is available. If there is something that is not listed that you are after don't hesitate to contact me on 0424 968 683.
ALL PRICES NEG.
Here is the car just before the accident:
Interior lights: $10
Brake Master Cylinder with Resovoir: $20
Front bar indicators: $20
Gear Knob: $15
Digital Dash Clock: $10
Indicator and wiper stalks: $10
Dash Pocket: $5
Shift boot w/ Surround: $15
GTR Dash Cluster: 129169km: Visual damage, all dials work OK: $80
Hazard light and Rear Demister switches: $10
Rear Ashtray: $5
Digital Climate Control: $30
Centre Console insert: $5
Handbrake Boot: $5
Brake Booster: $10
Smart Entrance Module: $15
Power Steering Resovoir: $10
R33 Taillights inc globe holders (Slight crack in Indicator): $50
Armrest Lid: $5
Straight Through 3" Cat (Welded 3" pipe through centre): $100
Standard Tank w/ Bosch 040 Internal Pump: $150
R33 Bootlid: Welded Spoiler Holes: White Duco: $100
Rear Cradle (Diff, Shafts, CAs, brakes, Tailshaft, All There): $350
Clutch Master Cylinder: $10
Rear Seats (Good Cond.) : $50
LHS Door (w/ Mirror, Door Card, Window Glass, etc, White Duco): $100
LHF Guard (Minor Damage): $200
Steering Wheel w/ Column (inc ignition barrel, everything from wheel to rack): $50
GTR Front Grille (Minor Damage): $20
Side Indicator (LHS): $10
Bonnet Latch: $10
Wiper Arms: $20
TEIN Supersport Coilovers w/ Adjustment Tools (GTST Front +Rear done 10000kms): $900
Work Wheel Nuts (Dyed blue and lightweight): $250
MORE TO BE ADDED....
  • 3 weeks later...
  • 3 years later...
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
