Parting out my 1995 Skyline GTST which has been in a accident. Everything from front to back EXCEPT FOR the front calipers, engine, computer and gearbox is available. If there is something that is not listed that you are after don't hesitate to contact me on 0424 968 683.
ALL PRICES NEG.
Here is the car just before the accident:
Interior lights: $10
Brake Master Cylinder with Resovoir: $20
Front bar indicators: $20
Gear Knob: $15
Digital Dash Clock: $10
Indicator and wiper stalks: $10
Dash Pocket: $5
Shift boot w/ Surround: $15
GTR Dash Cluster: 129169km: Visual damage, all dials work OK: $80
Hazard light and Rear Demister switches: $10
Rear Ashtray: $5
Digital Climate Control: $30
Centre Console insert: $5
Handbrake Boot: $5
Brake Booster: $10
Smart Entrance Module: $15
Power Steering Resovoir: $10
R33 Taillights inc globe holders (Slight crack in Indicator): $50
Armrest Lid: $5
Straight Through 3" Cat (Welded 3" pipe through centre): $100
Standard Tank w/ Bosch 040 Internal Pump: $150
R33 Bootlid: Welded Spoiler Holes: White Duco: $100
Rear Cradle (Diff, Shafts, CAs, brakes, Tailshaft, All There): $350
Clutch Master Cylinder: $10
Rear Seats (Good Cond.) : $50
LHS Door (w/ Mirror, Door Card, Window Glass, etc, White Duco): $100
LHF Guard (Minor Damage): $200
Steering Wheel w/ Column (inc ignition barrel, everything from wheel to rack): $50
GTR Front Grille (Minor Damage): $20
Side Indicator (LHS): $10
Bonnet Latch: $10
Wiper Arms: $20
TEIN Supersport Coilovers w/ Adjustment Tools (GTST Front +Rear done 10000kms): $900
Work Wheel Nuts (Dyed blue and lightweight): $250
MORE TO BE ADDED....
  • 3 weeks later...
  • 3 years later...
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
    • It's either an ignition failure or a fuel failure.
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
