we didnt get lost mohsen, we just drove faster than everyone else .. haha
was a good cruise fog sucked was wayyy longer than i thought it was gonna be.
maps .. not so sure about the maps possibly some of the street signs missing didnt help things but its a good idea to have approx distance's with instructions ie. turn right at X street 5.1kms so even if your not sure where the street is you can kind of guess it by distance and google/whereis should do all the calculations for you
otherwise good day car copped it a bit though few bumps/ditches
yeh maps my bad. usally do the run out and put all the kms down as u know with the members cruises. but due to holidays, rebulidin the line and gettin memberships out of the way i was unable to find time. my apologies alex.
i woke up at 9 30, and its a 2 hour drive to thomastown
maybe next time lol
Man your skyline must be broken
I can do Thomastown to Seaford in an hour..In my work ute.
Edited by Arthur T3
wheels looke tough nathan.
Been a while since you've seen my car alex. Had to go a decent rim and shortly a nice set of coilovers, ztune style skirts and pods to give it that extra finish.
yeh its lookin really good man
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
