Most people may know about this, but some may not read the NSW section.
http://www.skylinesaustralia.com/forums/topic/350755-s-a-u-n-s-w-wakefield-trackday/
I've committed and paid money so if anyone wants to try it out but wants a wing man, I'm willing to assist.
It's a little pricy at $210 for the day but.. for a Saturday and with timing included, it's a good deal. Better then a 3 point fine.
It would be great to see a bunch of ACT SAU's go up.
https://www.sau.com.au/forums/topic/352232-5th-march-sau-wakefield-track-day/
Hah I wouldn't be expecting any track brilliance from me at the start - only overtaking would be on the straight.
Will have to see how I go, the other one is very close to my Thailand trip. (yep poor me :P )
unfortunatly this is my birthday, so despite being a day i should be able to do what i want, like go on a track day and have fun destroying my car but im married, so instead i get to celebrate my birth, oh yay
Edited by swannie
  • 3 weeks later...
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
