Just FYI.... the first Texi in Sydney is June 12, and it's only $30 if it's your first time with us.
It's not *too* much of a shitful drive from here as Quakers Hill is just off the M7.
should be fine, how much power do you have?
Smoke-worthy power?
Im not sure, would be 140kw at the rears (ish) and about 390nM torque.
Enough for a 400m speed of 189km/h
Might bring a few sets of spares to see what gives good grip.
Hopefully I will have Pinky back on the road for the April local Motorkhana.. If all goes well, got my side indicators half installed, new mirrors on, will have my front indicators soon then get the front bar fitted and sprayed and all ready to go!
more details on the cressie kthx
Bought it as a finished project, built for daily duties and long cruises. Came with a trailer load of spares, literally.
When its washed up a bit I'll get some pics and maybe a mini-build/ fix it diary thread.
Currently waiting on the USA for cool-flex radiator hose couplers. (1.3/8" rubber joiners for the custom rad hoses)
So its not running.... missed very much too. The Holden Cruze/Ignis just doesnt do it for me :(
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
