Hi Everyone
I am in the market of stagea
I want to know if an M35 comes with the following
1. NISMO Option? like momo steering wheel, body kit, wheels and etc?
2. NISMO OPtions does come with DVD/Sat Nav - yes or no?
3. If there a NISMO Option - what does the car have? or what I should expect?
I found a car from an importer yard but im not 100% trusting all things he
said.
https://www.sau.com.au/forums/topic/352275-buying-an-m35-t-rs/
NISMO options include
Body kit
Steering wheel
Instrument cluster (speedo etc)
Gauge cluster (Boost, torque, battery - all white)
Suspension (S-Tunes)
Dump pipe
Cat-back exhaust
ECU
Wheels (LMgt4 for 2001-2004 and LMX5 for 2005+)
Air filter
I know I am missing more, but stuffed if I can remember
That one on Carsales is NOT a "Nismo" M35.
It has a Nismo kit, steering wheel and wheels (maybe suspension), but the M35 DID come as a complete optioned car from Nismo if you wanted, but it wasn't plated any differently.
they're all factory optional extra by NISMO.
Theres a pdf of the available options floating around here somewhere.. Not sure if it was Nismo Specific though.
Do you have the link for the carsales one?
Great for the info mate thanks for that - so it is not a legit nismo
anymore concrete details about the one from Carsales? cause it was priced a lil bit high
Priced high 'cause it looks nice.
A few guys here that own M35's and used to own M35's have been out to look at it and all said that it looks quite rough.
I'd like to see it, but be stuffed flying up to Sydney to do so.
Maybe ask zei20l and Bise-bee what they thought of it.
EDIT: Oh yeah, that isn't an M35 Nismo exhaust. Looks more Kakimoto or Blitz to me.
Aaron, here is your link
http://www.carsales.com.au/all-cars/dealer/details.aspx?Cr=7&R=9871689&keywords=&trecs=99&__sid=12DDC1725C97&__Ns=pCar_YearMade_Int32|1||pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|0&__Qpb=true&tsrc=allcarhome&__Nne=15&seot=1&__N=1216%201246%201247%201252%201282%204294963846%204294960181&silo=1011
Edited by iamhe77
  • Like 1
That price isn't too bad for all those extra's is it? If the K's are genuine then I personally would pay that for it. Iron Chef has one with a claimed 24xxxk's on it for about $19K which might be worth a look. Kristian is very honest and if I was buy one again I would definitely buy from him.
Edited by richzx
http://www.carsales....60181&silo=1011
Can you please link me to the people who actually seen this car?
what are the things I need to be more careful o? or things to look at when buying the car? or any m35?
I am taking a mechanic with me anyway
stephen looked at it, i havent, and wont bother after his comments to me about it.
its too cheap for a 2003 model with that mileage and the mods/additions on it. be wary of it if you do go to look at it
  • Like 1
Can you please PM me stephen's number I want to talk to him and gets his opinion + comments
he cant answer the phone at work, so its best to PM him on here so he can reply when possible.
his name is bis-e-bee
its also not a real nismo stagea. the badging and stickers are all in the wrong spot. the kit MIGHT be genuine
Bit melodramatic don't you think?
I am sure that the kit is genuine Nismo, as is the Nismo option steering wheel.... and the wheels and maybe the suspension (at a guess).
I wonder what ECU it has....
i like dramatising things :)
the ONLY thing id be worried about is the engine condition, and the apparent mileage.
who knows, might turn out to be a great buy! but id need to see it for myself to know for sure
I've seen it myself - from my not very good experience in importing the milage does not match the condition of the car
it easy to spot from the carpet alone - I know i want to buy it I am doing this so I can negotiate witht he yard so I won;t get
rip off.
I am going back to bring a mechanic with me to check the engine out and I am not racist but im not trusting the owner
