Hi,
Just seeing if anyone is heading along? Had a great time last time and got to meet a few of the SAU VIC members which was great.
Put in a leave form today and going to have a bash both days hopefully, was thinking of squeezing in winto on the friday but might eb a bit to much!!!!.
Just sending off my entry tomorrow so hopefully getting a spot.
Matt
https://www.sau.com.au/forums/topic/352326-piarc-phillip-island-12th-and-13th/
  • Replies 59
I'm going to try and go and Sat but am going to do Haunted Hills on the Sunday (another option if you are interested. Plenty of SAU people will be there - although if I was you I'd be sticking with PI for 2 days)
i have been told some stories about how quick you are mr snowman around PI, hoping i can tuck into your slip stream and you can pull me along :)
Last time i went to PI for the weekend the Haunted hills event was on at the same time as well which was a real shame. Looked at some of the footage and looks like a hoot.
Interested in splitting the cost of a garage on the Saturday?
Matt
Edited by boxheadmr
I posted my forms last week with a cash cheque for the saturday, would have been heaps easier with EFT and faxed or emailed entries, spose I will find out on the day if they accepted it.
Really didn't think I would ever need a proper cheque book.
Gonna try fit oil cooler this weekend, then should be ready to go.
I'm staying down on saturday night for a few beers, then going to the track on sunday to watch a few friends peddle their cars around.
Look out for the silver 32 sedan.
Cheers
Rob
Will be going down on Sunday for a look....
Hi,all,
I will be doing sunday at PI if my blue/black S15 is OK after saturday at Sandown with Driver Dynamic. A double header this time.My mate Dale will be doing the same two days with his GTR33. look forward to meet up with you guys.
Try to arrange accomdation for Sat night at PI, any suggestion?
Alex Cheung JAK Motorworks 0433878905
Well, don't want to jinx myself...but with these late night ass bleeding hours, provided Fri, Mon & Tues go to plan i should be good for taking thu/Fri off which means I am good to go. Will call PIARC when i get a minute to confirm space on Friday this week.
roy, i sent my entry form early this week so if you hear it is full would you mind letting me know please. I really hope not as i just booked accommodation:(
Alex, Accommodation at the Phillip Island ECO Lodge if you have some friends seems most affordable and still OK, we booked a 2 bed villa Fri-Sat and Sunday nights. If you are going let me know and i guess drop by for a cold one.
Looking forward to meet up with you at PI.my mobile is 0433 878905
Alex Cheung and Dale Kennedy
I cant come. :wacko: Pretty pissed off ATM. Its the last weekend we have our holiday house. We sold it and the settlement is Monday.
Apart from weird little huts to sleep in, the Eco lodge is pretty well equiped. They have a big pool and outside BBQ. Seeing you guys will only be sleeping there basically. It will be fine.
Have fun :action-smiley-069:
Edited by Tektrader69
Hi, met up with Matt and the boys and share the garage.had a great time at PI.unfortunately my S15 drop a cylender at Sandown on sat otherwise I will have a ball chasing Matt's gun S14.will have mine rebuilt quickly or swap the 2.2 stroker SR20 I got from Japan 319kw on pump fuel with a TD06/25G. look forward to the next track day.
was not the best weekend with miss firing that i thought had been fixed and then cracking the turbo manifold most probably due to the miss firing and having to run as little boost as possible.
Was nice to meet you all and whilst with all the troubles it was probably a weekend to forget it made up for it having a chat around the garage and seeing all the cars out on the track.
I have put together a clip for my tuner to try and work out what is the problem and replicate on the dyno but it gives you an idea of my frustration.
The running around with little or no boost and the big crack in my manifold was fun for a while until smoke started coming into the cabin. Might have to wait another couple of years to be able to afford to head down again but hopefully it will just be the driver and not the car as the limiting factor next time.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
