  • Replies 163
Posted Images
I have to say a MASSIVE thanks to Justin (the supplier of these injectors) for the massive help he's given me with a few problems I've had that were out of his control. His service was second to none and I rate his professionalism and helpfulness as some of the best out there. Don't even hesitate to think about buying from him; just do it!
In other news, I've got the car running as can be seen in the video posted above, I just need to get it in for a tune now and all will be sweet
no group buy ends 04/03/11 and refer to quote
All prices above are for a group buy only. This assumes 1 order, 1 payment, 1 delivery address. Payment via bank deposit only. Paypal payment will incur 2.4% surcharge. Please allow up to 2 weeks after payment for order to be dispatched.
how ever it is possible for you to pay full price from the supplier and get your own shipped to you
yep, thanks its just standard
i need to contact the supplier to find out about something otherwise you will need
80lb Siemens $345,
wiring harness $42,
Blue fuel rail $225
shipping $25 Total $637
More information taken straight of his ebay page
Available in:
Red and blue for RB30. Chrome can be optioned for $20 extra.
Red, blue and gold for RB26. Please note RB26 rail kit can run both 11mm and 14mm Oring injectors. Chrome can be optioned for $20 extra. Gold currently out of stock.
Blue only for RB25 (suitable for R33 RB25 only)
Please specify which of the above you require when ordering.
Rail kits do not come with injectors. Aftermarket fuel regulator will need to be used.
I was after a pic of the id2000 rail
Cheers
he said the fuel rail suits the injectors which suit your car picture's are very similar
also
just got off the phone to the supplier and he can supply 10.5mm hats for the 3/4 length injectors
they will be more expensive than the 11mm hat that is supplied for aftermarket rails that take 11mm
when ordering please do as much asking of your tuner what sort of options you have available, i would hate for people to order the wrong parts
for the r32's do the injectors have to be Hi-Impedance?
ive got 700cc siemens low-impedance in my 32 atm . . .
Edited by I8EE
does your 32 run the same low impedance thing that GTR's run?
On Edge - any type of aftermarket FPR will work im getting prices on some Tomei ones
also
Good news on the RB26 height adapters for use with the EV14 Bosch injectors. I can do the 10.5mm adapter for $8ea extra on top of the original price. I will need approx 2 weeks lead time though once we have numbers.
Good news for the 80lb boys, please put me down steve for 80lb injectors to suit r33 rb25, also fuel rail an adaptors if neccesary.
Maybe a z32 aswell mine maybe stuffed ill let you know on that one so don't put me down as yet.
1000cc are 3/4 length and need the height adapters
you can get the 80lb/h close the 1000cc (95lb/h) with more fuel pressure your tuner can advise on this though
**note**
price change applied to those wanting the 80lb/h injectors
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
