Okay I have a vipec plug-in ecu. Now when it was tuned it turns out that the aircon wasn't working. The compressor itself wasn't activating. Now I have since had that fixed, it was a problem with the climate control unit, and I have had an extra switch put in to activate it.
Now the problem is whenever the aircon is activated the car has a tendency to stall when stopping, it appears that the ecu doesn't increase the revs in time to prevent the stall. It normally doesn't do this when the aircon is off. I presume this is due to less load on the engine. What would be the best way to fix this? Increase the idle speed? As it also tends to idle a bit low when the aircon is on.
https://www.sau.com.au/forums/topic/353082-vipec-idle-issue/
In the ECU software increase the values in this table a bit and it should increase the revs when the aircon is on.
Idle Speed Control > Idle-Up Tables > Aircon Step
You could also check the RPM lockout value (mine is set at 400, however i have never had aircon so dont know if this is high enough with it on)
Idle Speed Control > Idle Speed Control > RPM Lockout
RPM Lockout is at 800rpm
change my Aircon step from 5.1 to 8.1 across the the board. Will see if this makes a difference. It did seem to help the idle of the car when I had the car connected.
Ever since I got my AC working on the Vipec the idle wasn't perfect with it on, so I played around with it a bit and it was good enough (not perfect) so I left it like that.
However I was just thinking, is the AAC actually set up on the base map?! I don't remember ever seeing it on the Aux output?
EDIT: I just loaded up VTS and noticed it is in its own folder called Idle Speed Control. However what output is that actually using?
I have the same issue, really low idle when aircon is on with vipec plug in. mine is in need of a retune once i get new turbos etc so il get it fixed then, but i never had aircon regassed when ecu was installed either so now i know im not the only one with the problem lol
for a list of all analog/digital outputs and inputs and what they control, get the gtst/gtr manual off the vipec website.
the help file is ACTUALLY helpful. its by far the most comprehensive guide ive read. any issue ive had with my vipec ive searched the help file and its explained it all there in great detail, and it gives you a good idea on how it works.
Yeah the help file is great, I use it all the time. Makes it so much easier.
I got it to idle with the aircon on without stalling now which is great, however it still hunts up and down from 800-900 a bit. Not really sure how to smooth that out. Will keep trying.
Ahh good thinking. Yeah it is closed loop and the deadband is set to 30rpm. I'll try setting it to 100rpm or something and see how that goes.
So many thing to adjust!! Haha.
If you want it to idle properly you need proportional spark as well as closed loop idle control. The trick is to find the advance at which +/-10 degrees of timing gives you an equal increase/drop in rpm then apply your delta igntion numbers corresponding to the rpm you found and make your base idle timing the number you found earlier. Make sure you turn off all IAC control while doing this though.
Open up the bounds on the idle control to at least 100-150rpm you want it to do very little until +/-200 rpm from you desired idle speed..
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
