Hey guys, ok so i bought an R31 with decent power, box is screwed but ive just bought a new one and the clutch is slipping so im thinking ill change that at the same time. what clutch should i get?
I need one to handle 300rwkw or close to just wanted to know my options. thanks guys!
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/
I have searched and it seems jim berry is the best for track and there isnt much more about clutch options, im asking what people have used that works well on the street because im not going to be putting 300kw thru it for long periods of time ( only now and then ) and im not planning on dumping the clutch at 7000rpm, i just want to know if someone is in the same position as me and what they have used that worked
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5660880
jims a great guy to deal with, but hes sooo over priced
i got a modded exedy 5 puk from a guy in sydney (Parramatta?) 4000ish pound clamp load with carbonic pads/puks.
Jim quoted around $7-900, the other guy (who i would of sworn was jims long lost brother, really nice) was $360 including shipping to act.
so far good for 285kw and 700ish nm's
if you want ill track down where/who it is.
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5661846
wow ok, i really dont have 2200 to spend on a clutch right now as im still spending money ironing the bugs out of this engine, ( one day ill put it in a 32 with a 25 head ), i got lucky and picked this car up with a fully forged and balanced bottom end for 3k. i use this car as a daily for now and sounds like the guy from sydney is my best option. when i get abit more serious with it and track it ill go for the better clutch. could you pm me the number so i can call and get one sent to me? cheers :thumbsup:
Edited by mungy
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5661921
i run an exedy HHHDBC with 325rwkw
not the best for a daily, but grips up hard and fast on track, i'm absolutely in love with it. well under a grand.
jim berry's are nice... but my legs are nicer ;)
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5662364
for anyone else interested -
K B Clutch Engineering
143 Coreen Ave, Penrith, NSW 2750
Outer West Sydney, Western Sydney
p: 02 47321692
Speak to Keith, he's the man. really top guy to deal with.
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5667271
I've just heard more bad things then good things lately about Jim berry clutches. There's a thread from not long ago where one of his clutches welded itself to the flywheel. Apparently it's not the first time this has happened
Nismo twin plates are great, but if it's out of your price range I highly recoend NPC. After having an NPC I wouldnt recommend anything else. It grips hard and is quite soft for what it is. They are quite reasonably priced to
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5669329
hey where do you get the TRIPLE HDB, i have talked to atap ( clutch supplier for my work ) and then exedy all they have is "NSK 7056HDB" which is rated to 330rwkw and is bout $600 without trade discount. is that the one your talking bout.
the description is on their website and. i am just interested as i am going to buy one but says nothing bout HHHDBC
Size, Spline OD & No. of Teeth
240 x 25.5 x 24
Flywheel Profile
Flat
Additional parts - not included in kit
Alignment Tool
DCT-01
Spigot Bearing
PB-22
The Heavy Duty Button (HDB suffix) clutch kits are manufactured to meet the demands of various forms of amateur drift, circuit, rally and drag racing and are assembled from 100% new component parts. All HDB kits are supplied with high clamp load clutch cover assemblies and ceramic button clutch discs with sprung dampers.
Edited by PaulosECR33
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5684232
NPC FTW..they build to your desired specs and ships straight to your door (or the mechanic in my case)
super easy to drive and bites hard every time. when it burns out, you can send it back to them to get rebuilt with new clutch plate etc
https://www.sau.com.au/forums/topic/353237-300rwkw-clutch/#findComment-5684984
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
