  • Replies 66
Maybe Admaz, on the cruise tomoroow you could apply the suplex or pile driver manouver on James, get him and the gang off their bums to finalise the VIC thing. I seriously think at this stage that's all that is holding the deal up..[james can confirm]
Yes, it will include flywheels. As not to step on other distributors toes, they suggested to limit SAU to Skyline/Nissan models only & anything from heavy duty up.
..[Jamezilla can confirm]
Shouldn't be taking this long???? Also be on the look out.. once Jamez sorts out this VIC thing out, I have a contact at a tyre manufacturer lined up to supply SAU permitting. ps: no crappy make either :) [spelling] OH-FEED-EL-SHUN :D
hey buddy... i'm defintiely in need of a new clutch, considering i have just completed some engine work and my standard clutch can't handle the extra power; so it's time to spend some MORE bloody money..
i'd be after a new clutch system and a lightweight fly wheel.. how far away are we to this deal, in your opinion? i have a track day coming up, so I would probably need to get it after I completely kill the clutch on the day.. so ASAP would be great..
cheers man..
Giles
there is a hand full of people here who need a clutch asap.. is there any way something can be arranged for now? maybe a group buy of heavy dupty GTR/GTST clutchs from your rep? pls guys alot of us are waiting on you!
OK Guys below is a list of people who ergently need clutchs and have expressed interest in this thread. Can we organise either a group buy or a discount for buying so many or some sort of club discount asap.
Stirlo_GTR
gts4_fun
vendetta
Adzmax
Bass Junky
benm
myr332
ajmck
Black33
MM2death
gatty
phorj
NickR33
Blitz_R33
Gizmo73
ed R34
*plus I am sure there will be more if something takes off..
Aaaah! forgot to give an update.. sorry guys.
Here's where we are at,
I pretty much secured a deal where SAU would become a "licensed distributor" on all exedy products limited to skyline models. They needed some other details which I felt would be best handled by the senior/pensioner/war veteran :P SAU guys, so I have handed everything over to James "jamezilla" and hopefully he will keep you updated.
I wouldn't expect to see this happen any time too soon, I'm after a clutch and flywheel too but I don't think it will go ahead untill the Vic SAU is up and running. If Mesh or James are reading this can you confirm??
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
