got amate here at work that beleives a kkr560 would be alot better than a hypergear atr43 G3. i have tried to explain to him the quality of the kkr560 and the problems everyone has had with them. what your opinions so we can stop this debate.
ps this is a debate of the turbos on a rb25det
https://www.sau.com.au/forums/topic/353529-kkr560-or-atr43g3/
define better?
build quality?
warranty support? ease of installation? transistent throttle response? wide open throttle response? resistance to surge? corrected airflow vs pressure ratio? options of bearing and wheel variants?
do you see the issue? so many variants, options, and it's open to interpretation
or are you comparing for a simple flat out which makes more rwkw at 20psi ?
i reckon both are ordinary turbochargers and there are a lot better units out there, but if i had to put money on one of them i would put $5 on the KKR over the atr43
atr43 is alot better overall then the KKR turbos in my opinion. As seen in the hypergear thread there are several results and people that go with it are very happy as if on a budget you cant beat it. On the other hand all you hear about people using KKR is poor performance and having issues with them. Also youll get alot more support with a hypergear turbo as stao is more than happy to help hes customers.
If it's KKR, does it matter where you are? You'll still have to get it taken off and sent somewhere. Stao has a quick turnaround with warranty issues, and will be VERY helpful with troubleshooting and any assistance he can give you....get that from another manufacturer (other than GCG, I'm sure they're just as good)
've got a KKR560 in my 33. Friend has a 34 with stock turbo, both have exhausts, powerfc's, front mounts etc... I can't believe how much more responsive his car is. Mines got more power, but it's much less driveable on the street.
Where you that suprised?
I mean really.
    • This is aem disk setting in aem tuner and still 180 dgree off or ignition on exhaust cycle is it from cas it self as cas seems wouldn’t fit in cam shaft if wrong position and wiring been verified any ideas
    • Oh yeah that would work excellent. Should be the same diff housing & everything. Shoot me a text or call me 260-750-2246 -Cody
    • Oh right, I didn't realise it was your car. Please do! Makes me feel better about mine. I also have a big scrape on the front left bumper where someone presumably used the wall to guide the car into a parking spot  But somehow all the funds go towards mechanical things and the cosmetics stay forever unfinished... Interesting, I don't think I have seen it before. But after seeing @PranK's rusty roofline on the BMW I'd probably leave it alone. Wouldn't want water to get in there.
    • Thanks mate, thought you might know the answer.
    • Infiniti US are teasing a manual Q50 as a way to refresh a (very old) model. https://torquecafe.com/manual-performance-sedans-arent-dead-yet/ Can't be too technically difficult given the Z has the same motor with a manual gearbox......here's hoping there is a JDM version we can import here, that would save me a world of headaches
