  • Replies 199
Yeah I shall volunteer for this role. Sounds like an awesome time out and the thoughts of going out later and hitting some clubs just sets it off lol
keen.
how hard is it to enter clubsprint class as a privateer? ive been playing around with aerodynamics in scale... the 33's getting a full sealed underbody but seeing the track i dont think it will have enough power still :S
Oh bad luck for him.
Probably move to JIC crimped fittings on braided hose and avoid that happening again. Its never much fun!
(This is how we do all of our GTR lines - high pressure oil leaks are always bad news on the track)
yeah wont be using pushlock again... too risky. had a chat to my local hydralink guy today and will go with single wire hydraulic hose with crimped JIC fittings..that shit aint coming off lol.
in the end damage was spun number 2 bearing and a cracked crank...am attempting to rebuild it using new crank, acl race bearings, APR rod bolts and N1 oil pump. hopefully should cover the bases
oh and cheers for the offer! i may still hit you up. depends how busy my hydralink guy is.
Edited by Simon-S14
haha yeah ive been watching that thread for ages... the mind boggles at how nissan get it so right sometimes.. and yet so many ppl have issues with N1 pumps. it begs the question was there a prob with the design/manufacture of the pump or a problem with the fitting/rest of the build that contributed to the failure.
i think i'll either reuse the OEM neo pump (i inspected it... looks brand new still.. no bearing material went thro it. or go a billet geat set for the oem housing.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
