Hi all was driving home work tonight cruising along and my S1 25g with stock N/A RB25de started to run very sluggish s0o pull over switch her off but she will not start, got power, faul pump and starter goes got comprestion,inject pulse and spark but wont start.
Thinking maybe has jumped a tooth in the timing???
Can anyone please help
Cheers
Edited by 17yostagea
https://www.sau.com.au/forums/topic/353943-stagea-brake-down/
im apprentices mechanic so call my boss out at 8:30pm out with the plugs in to test for spark and pules
got it towed to work today took off the coveres and there just bit of timing belt everywhere and jumped about 6 teeth just peeled the top half off the teeth in belt il get pics tomorrow
Fingers crossed no real damage
right....well then you already know it is likely to be bad then.
the only rb know for sure is non interferance is rb20. if rb25det is interferance and rb25de has higher compression....it is very unlikely to be OK.
Come on Duncan don't be a spoil sport, I am pretty sure JP showed you the timing belt that came off my R33 when the idler bearing seized and stripped the timing belt.
New belt fitted, it started and purred like a kitten. :banana:
I have no chance of winning Powerball now. :no:
yeah 25det and 26dett definately are interferance. Not really surprised rb30e is non, I wonder what a hybrid rb30det is, pretty likely it will be interferance?
Andrew....damn straight you have used up all your luck! I broke a cam a few years back, that was carnage for valves and pistons :(
could be onto something there iv got a new belt to fit tomoz what esle u do to it just the belt?? and away u went?
The mechanics expected they were going to take the head off but figured it was worth trying to fit a belt and idler bearings and then turn it over by hand to see what would happen. It turned ok, so they cranked it and it started like normal.
There is no joy in getting the bill for a new timing belt (etc) but in this case it beats the hell out of a new engine.
I have seen teeth stripped off the belt before and every time the belt had been subjected to engine oil leaking on it. Look for oil leaks and check bearings I would like to know what caused the belt to break.
Should know today
$360 from nissan, is it possible to get second hand?
Our local bloke got a full reco set, both pulleys and belt for $225. :banana:
Edited by 66yostagea
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
