A lightened flywheel is excellent for track but for street driving i wouldn't even bother. as others have said its a pain in the arse. initial start-up and low revs your car will start to jerk back and forth.
do you speak from personal experience?
on mine initial start up is exactly the same as stock. no jerking back and forth involved.. whats this about low revs eh? mine still revs just the same.
is easier to stall though.
i've been driving around for a month now in my mates car with an exedy lightened flywheel... I have to say i still prefer my stock one.
the exedy isn't drasticly light, but imho it is annoying on the street, and doesn't give any noticeable difference when caining it
Half the time people blame the flywheel, when in fact it's the clutch and pressure plate making it a bitch to drive.
I had a 6puk button clutch in mine with a 1250KG pressure plate, on a 4.5KG flywheel. never had stalling issues myself, could drive it off the mark at 800RPM... Mind you, hand the keys to friends and because of the bitey clutch, it took them 50 goes to get moving.
Changed to an organic clutch plate and anyone who drove it afterwards loved it...
I agree about an organic clutch making it easy to drive, but you can still blame the flywheel equally in that scenario, because it's a catalyst in the equation - an heavier flywheel on take off will be more forgiving, regardless of the clutch type.
To use a weird analogy, it's like blaming your bald tyres for not getting traction off the line, when your diff is still a single spinner. You can amend either to improve traction.
Whoever said the flywheel acting as a dampener is totally correct.
also in furtherance of what Dan said, the inertia of the heavier flywheel makes a car far nicer to drive in areas where you are having alot of transient throttle conditions, which is a fancy way of saying, when your bumper to bumper, speeding up and then braking every 20 metres a very light one will drive like an absolute dog.
Edited by Nee-san
Another real world example to demonstrate said effects, as far as daily driving is concerned, is throttle on/off situations or inconsistency in throttle control, e.g. bumpy surfaces in low gears or speed bumps. In most cars I clutch in and slip for a speed bump anyway, but sometimes I coast over it in 1st gear and whilst manageable with a steady throttle foot, sometimes the engine RPM will bounce around (bouncing the chassis with it) and take some time to stabilise. This will be worse with a lightened flywheel. Same with bumper to bumper traffic, as mentioned above, when you can't get out of 1st...you're either in for a rough ride or you'll burn your clutch to death.
EDIT: Oops, sorry for the first sentence of that Nee-san, it sounds a lot like what you've just said.
I habitually let the clutch out without any accell at all. Lightened flywheels will jerk the car more, from personal experience. But in the hands of a person who uses some gas with the clutch, they probably wouldnt notice it, no. I think the initial reason for lightened flywheels was to try and sync the engine revs with your gear change speed. Since racers generally change through gears faster, having the engine drop revs faster will help with shifting, saves planting the clutch to get the engine (spinning at 8000) to match the clutch (spinning at 5000)
Edited by GTRPowa
It's cool man, some people need to be told more then once :P
  • 6 months later...
Thread update - Fitted a 6.8kg Revsolution steel billet flywheel from NPC (very nice bit of kit) and I love it!
The engine is more responsive and easier to drive... I haven't found any downside to it at all.
In fact after driving around town, on the motorway and through the twisty stuff IMO it is better then the stock item in every respect.
Definately a recommended mod for the few hundred $$$ that it costs and I was replacing the clutch anyway.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
