f/s-
i have a 38mm turbosmart wastegate.
fitted with a 7psi spring.
it held 15psi FLAT on my 25 with 3076r.
ONLY upgrading due to getting a craig helps merge collector manifold and HAVING to go 44mm or bigger :ermm:
used for 100km's
$300
up for sale my 32 CBF fixing it
up for sale is my r32,gts 4wd turbo AUTOMATIC.
black in colour
with 146000kms
rb20 DET
3inch cat back exhaust
17inch black r34 gtt rims
tinted windows
very clean body
bad points are little things like a few plastics in the interior are broken
NEEDS r/h side controll arm, front bar and tire to be swapped over as it has a puncture but i have a tire to go on.
and no rego but it can be all you have to do is go to the rego office and pay for it.
price is firm as its CHEAP as CHIPS , no swaps BUT i want a bigger turbo for my 33 so maybe cash a turbo and cash.
text me on 0415232397 located in mansfield pk
pics here...http://nissansilvia.com/forums/index.php?showtopic=463264
4 Sale
R32 ISC Rear camber arms, Brand spanking!
Bought coz they were going to on the track car but decided to take the ones off the streeter instead.
Bought for $179 (+15 bucks postage i think).
Sell for $150
z32 afm setup for 5-pin plug (suit Rb20, early-mid Rb25) still for sale - $100
I have some sets of Front Brake disc rotors (pairs) for sale:
1x DBA4000 296mm x 30mm 99% new. R32 GTR
unused from project, upgraded to 324mm set
had slight surface moisture rust, sandpapered off as per pic
$100
1x RDA 280mm x 30mm 90% new. R32 GTst, Stagea S1
had slight surface moisture rust from leaking shed, sandpapered off
$80
1x RDA 280 x 29mm 75% new. Stagea s1, R32 GTsT
$70
1x stagea S1 front brake caliper set, with braided line as pictured, new pads
$50
need it gone
thanks
FOR SALE:
Carbon bonnet for r34 300$
Blitz LM fmi return flow type r34/33 300$
R34 Nismo/Altia rear bumper, original not fibre glass copy 150$
pm me if your interested!
PM sent for bonnet and FMIC
cheers
for sale
genuine r34 aero front bar 500 neg
fibreglass aero front bar brand new still in gel coat, no pic 150 neg
brand new never been used greddy dual pillar gauge holder for r34 gtt/gtr 120 neg
msg or ring dylan on 0433091947
Bendix Ultimate Pads + Discs To Suit R33 Skyline
Includes:
Front Discs x2
Rear Discs x2
Front Pads x2
Rear Pads x2
Not sure on the true value of these, so if some makes a good offer i will probably take it
These are also listed on ebay at the moment, here's the link to view pics of the dics and pads
http://cgi.ebay.com.au/Complete-Set-Brakes...=item3a5f3a5ae5
The discs have hardly a lip at all on them at all, the front is like not even a 1mm lip i rekon,
And as for the rear discs, they just feel like there is no lip, just where the pad doesn't reach the edge of the disc its a lil rough, which is normal
The pads have 7mm all round front and rear, and they are Bendix Ultimate,
Do not want to post as too heavy being metal, obvious reasons ofcoarse. Would prefer pickup only
Contact me through here or send me an e-mail at [email protected]
Locater in craigmore 5114
r32 standard turbo. Came off the car running stock boost before I did a turbo/injector upgrade. $200.
Set of rb20 injectors $100
rb20 airflow meter $70
prices are neg. I am willing to swap parts for the following things--
Bonnet. Drivers side front guard. Drivers side head light and indicator to suit r32.
Pm for details thanks
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
