really needed to quote the whole flupping post for a 1 line reply? faaark.
well like this one smartass all i did was hit reply. not my fault sau is setout this way on my browser. i hate it and only sau does it. dont like it take it up with them :D
granted. but theres also the facility to preview and edit posts.
so why didnt ya edit it once u know it was munted?
-D
sold my rb20 engine so gearbox up for sale:
MINT RB20 gearbox with shifter...can include front yoke if needed $500
rb20/25 exedy heavy duty clutch 90% meat left $100
ALSO WRECKING turbo R33 1996 SERIES 1.5 GREY IN COLOUR
ALL PARTS AVALIBLE MINUS GEARBOX
can hear engine running any tests on are welcome
text me anytime: 0422030855
located in angle park
Edited by hcR324door
Hey guys and girls
Got a few things for sale. All parts located in Dernancourt, South Aus.
Prices are Or Nearest Offer. Note, that if you lowball in a spectacular way, I will laugh out loud.
SAAS steering wheel - $50
2x Kumho ku36 tyres, good for skids (225/45/17) - $20
SR20de Front Brake Calipers - $70
SR20de Front rotors - $10
SR20de brake master - $20
s13 bonnet w/damage (black) - $10
3" polished metal pipe - $20
drift 3" silicone joiner - $10
s13 stock turbo dump - $50
s13 stereo surround - $20
kenwood monoblock 1000w amp (KAC-8104D) - $120
4 channel 800w amp - $100
S15 T28bb turbo (damaged intake fins, minimal shaft play though, see pics)- $300
SR20det redtop bare engine (bottom end knock, suit rebuild, has sr20de cams) - $400
Nintendo Wii package, in great condition - $250
Nintendo Wii console
2x Controllers
2x nun-chucks
De Blob
Need for Speed Undercover
Wii Sports
Super Smash Bro's Brawl for Wii (As new condition, never used) - $50
Graphics Calculator - $50
Stargate SG1 S10 dvds - $25
Assassins Creed 1 w/collectors tin - $30
Thats all for now.
Contact me either by PM here or on my mobile (sms prefered)
0402 035 914
-Sam
1) mint full set of Buddy Club P1 racing wheels in hypermax gold with good condition Kumho KU36 semi-slicks all round plus Work annodized valves.
17 x 9 + 37 & 17 x 8 + 32 255/40/17 & 235/45/17
$1100
2) full set of ISC N1 coilovers for R33 GTS-T. 12kg front, 8kg rear. Immaculate condition, recently purchased and stripped off a car I bought.
$650
Pm or call on 0400 259 598 if interested.
Chris
Edited by zirty two!
Would like these items gone today so I can buy booze tonight! cheap cheap!!
PM Enquiries.
Kenwood KDC-MP443U MP3/AUX/USB - $60
MB Quart 6" Coaxials - 40wrms - $50.
Edited by nicr4wks
PM Enquiries.
asking a friend if they want to radio
my friend will take it
cleaned out shed and got these r32 parts.
got the standard wheels powder coated white
standard turbo
standard mirrors
GFB bleed valve
momo steering wheel
battery and starter motor cable
standard side indicators that are orange not clear
i'm taking offers for these. so just make an offer and u will more then likely get it
for sale r31 silo. legal registered rb20det motor and box. 160rwkw after recent remap thanx to decs from garage 7.
411 gears with minispool diff running 28 spline axels. upgraded brakes to suit rb20det (front) vp rear calipers. hydro handbrake installed by decs of garage 7 but in stock position so cops dont know and hiden under center consol. volts temp boost and oip pressure guages (legal position) tacho with shift light. full silo interior and also bucket seat on 31 rails not installed. brand new walboro fuel pump. lowered on monroe gas shocks all round. red lowered front springs (unsure of brand) and r32 rear springs. catch can. fmic with custom stainless tubing behine front lights. full turbo back exhaust with decat pipe. boost t set at 12psi. prob alot more but cant remember. was gunna ask 6.5k but come make an offer. just lost my job and need money for morgage.
this car was set up to drift as i was going to use it as track car. all it needs is coilys and its all go. also have ceffy front end that can come with at right price.
this car is also now used as daily
pm me or ring 0434223083
Pics?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
