Versus rims
2 x 18 x 9.5
2 x 18 x 8
1 has slight gutter rash maybe 15cm long. Rest are in mint condition
Looking for $900 ono tires (3) inc but pretty worn.
Mobile: 0401 355 434
Pics
Price Drop $800 want them gone.
Up for sale is a set of R33 GTR sway bars.
I bought these off a while back and they don't fit my car(Auto)
They will fit manual C34 series 1 or 2 stagea.
the rear is 22 or 24mm solid from memory, a great upgrade over the standard 17mm hollow bar.
Selling them for less than i paid for them.
Rear sway bar comes with rubbers, u bolts and links to suit.
$150 + postage
Located south of Adelaide
Pm or call me - 0423 10 11 10
stock rear sway bar compared to r33GTR sway bar
N13 pulsar for sale!!! Got 15 inch wheels, whiteline front strut brace, lowered king spings with new shocks, exhaust! Keen to swap for some wheels to suit my 32! Open to offers and cash offers too.
msg me for anymore details or pics of the car.
Brad - 0430033573
100k service kit for GTT, I don't have the car anymore so no longer required: rb25det neo water pump, gates timing belt, tensioner bearing, idler bearing, 3x Ancillary belts
post-47337-0-94923400-1291524979_thumb.jpgpost-47337-0-36269200-1291525011_thumb.jpgpost-47337-0-72578400-1291525052_thumb.jpgpost-47337-0-98687800-1291525128_thumb.jpg
$400
Pm me or sms me on 0433348748 for further info..
$150 + postage
Would this bolt on to a R33 GTST??
If so then i am very keen
Set of Lenso D1R's with tyres and centrecaps, near new, no rash, excellent condition.
front: 17x9 +35, 225/45 tyres near new
rear: 17x10 +15, 235/45 tyres near new
$1,100
call or txt 0422140579
Edited by banhzSIIR33
FS:
Brand New Tomei Sump Baffle $280 rrp $399 at JJR
Used Tein Fixed Height Coilovers, Type HR to suit R32 GTR/GTS4 - $600 negotiable
Used Bilstein Fixed Height Coilovers, unsure what type but they handle very nicely. Slightly lower than the Teins. To suit R32 GTR/GTS4 - $600 negotiable
Used Toyo T1R Proxes with camber wear x4 to suit 16x8 stock gtr rim (225wide), $50 or a bottle of wild the sphincter of the universe
pics upon request
-D
$1,100
do you have a pic of them fitted?
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
